Question about ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC
Java isn't running - ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC
    Sergeant:
  • 169 Answers
Check on the bottom of your browser for an exclaimation mark..double-click it and the location of the errors in your code will be mentioned in the resulting window. Fix it-& try again!
Posted on Jan 29, 2013
Java isn't working
try this uninstall java everything not ony what windows add and remove takes.look in C:\remove it all.now install new java.
Jan 26, 2013 | HP Black Envy 23-C030 All-in-One Desktop...
My htc java can't work
If you're talking about an android phone, there is no java plugin for android. It will not work. You might possibly be downloading the PC version of java and trying to install it on your phone, which will not work. If you're using an older phone with a mobile java plugin and you're trying to install a .jar file. It probably isn't compatible with your system. If you could clarify which model you are using it would be helpful!
Nov 03, 2012 | Cell Phones
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
Invalid jar on samsung chat322
This means that a JAVA program isn't working correctly, this can be due to a myriad of reasons. You will need to obtain the manual and check out how and what to do in this case, often it is because JAVA isn't installed?
Sep 10, 2011 | Cell Phones
Yahoo mail required me to download java script so a can register a new e-mail address
Hello!
The problem is in the browser. If you aren't able to view javascript content, then maybe your browser isn't up to date.
Another cause might be that Javascript is deactivated. To activate it again, search in the options menu in your browser.
May 20, 2011 | Sun Java Programming Language (cdj-275)
Java not loading it is saying not found
You need to have downloaded the latest Java Development Kit: http://www.oracle.com/technetwork/java/javase/downloads/jdk-6u25-download-346242.html
Then once its installed open the command line (type cmd into the search bar and hit enter). Type java and hit enter into the command line and it should come up with commands to do regarding Java. If so then it has found it.
Uninstall and reinstall if you have already done this as sometimes the 'CLASSPATH' becomes faulty. If it still didn't work right-click My Computer -> Properties -> Advanced System Settings -> Environment Variables and look for a variable called 'CLASSPATH'. If it isn't there you need to add a new one and point it to where you installed Java.
May 07, 2011 | Sun Computers & Internet
I can't scroll down my java applications
First go to your control panel under the start menu and find the Java application. Once open, go to the update tab and click the 'Update Now' button.
After the update is complete, go back to the control panel under the start menu and open the 'Add or Remove Programs' application. Sort the list alphabetically if it is not already and check your java installations. If there is more than one version installed, remove all versions except the newest version.
Next, after checking java installations, go back to the 'Java' application in the control panel under the start menu. On the 'General' tab, click the 'Settings...' button. Click the 'Delete Files' button and confirm the deletion of 'Application and Applets' and 'Trace and Log Files'.
Lastly, in whichever browser you are using, clear all temporary internet files and cookies and close all windows for the browser. Once the browser is restarted, retest your issue.
This fixes most issues that I have run into using Java based applications.
Regards,
Dan
IT Professional
May 04, 2011 | Computers & Internet
When i try to run games in my samsung corby the error comes `java error no memory available `
when i try to run games in my Samsung Corby Pro the error comes "java error no memory available"
Feb 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
53 people viewed this question
Top ArcMedia Computers & Internet Experts
Computer Links
Alun Cox
Robin Hill
Robin Hill
Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
