My Laptop suddenly takes 15 minutes to turn on from the loading screening (where it says acer after its turned on and the blue loading bar is going) and simple tasks are now slower, such as the media player cannot play songs without it skipping, the mouse lags and other software seems to take longer to load.
  • hackysacker0 Jan 26, 2009
    Thats the thing though. The laptop was acting a little slow about a month ago so I bought two 2gb kingston ram sticks to toss in there. It worked great! Then I defragmented and disk cleaned up and cleaned out all the temp internet folders and cookies, all the basics, to get the extra speed. It worked fine for a month and then suddenly one day it took 15 minutes to turn on for no real reason. I don't use any software that would slow it down. Even before I put the sticks in it wasn't that slow. I took out the ram and placed them back in to see if it had dislodged but that didn't correct the problem. Could it be that the sticks have suddenly become faulty, or do I need new drivers? For awhile, I was beginning to think it was my video card???
    Really?? How does the Hdrive effect the speed of the computer turning on or the music skipping? The computer is practically new, hard drives last longer than a year? Though, that is a good Idea, i'll back up my files just in case. :)
  • 741 Answers
The best thing you can do is add more RAM. As more programs and documents are loaded the more RAM it needs. However, there are also a couple of other things you can try first. This will clean up all the old /tmp files that are not needed and also fix your hard drive so all the data is together and not spread out.
click on start>programs>accessories>system tools>disk cleanup. Run this first to get rid of the junk files that are left on your computer by websites
After the disk cleanup go back to the same location and run Defrag.
Each time you delete a file it leaves a blank space on the hard drive. after a while it takes longer to find files. The defrag will push all the data together in a row so it is faster to find.
Hope this helps.
Don't forget to rate this solution before you log off.
Posted on Jan 26, 2009
  • Randall  Trahan
    Randall Trahan Jan 26, 2009
    Sounds like your hard drive is almost on the way out...but don't take that as a "for sure"...but if you start hearing a clicking sound when you start up, its the hard drive. Just to be safe you should do a back up on all of your documents, favorites, emails, etc.
Acer Aspire 5920g laptop My computer suddenly crashed during an update coming up with a blue screen. Since then I have tried to use the recovery disks. After successfully loading and showing "windows...
Hi
it may be worth trying this
power up and press the Alt+F10 as soon as possible and this may take you into the factory restore option
where you should have about 2 different options of recovery
just follow the on screen instructions
i hope you can get it sorted
Jun 23, 2011 | Acer Computers & Internet
I have an acer laptop 5735-4061. I was using this morning just fine. I got up to go do something and then I came back and there was a black screen with a blue bar in the middle of the screen. I says...
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Feb 04, 2011 | Acer Aspire 5735 Notebook
My acer wont load when i first turn on, or load,gives 2 loud beep
Sounds like the hard drive is going bad. Take out the hard drive and see if the laptop behaves like that if it doesn't then you know the hard drive is bad. If it still does then it could be a motherboard problem.. With it making those beeping noises when you first turn it on, they keyboard could be going bad because that would make a laptop start beeping like that as well.
May 19, 2010 | Acer Aspire 5100 Notebook
I have FZ31s. My laptops battery drains to fast,within 15 minutes more or less.Last night the battery went out. So I turned my laptop off.But today when turned on my laptop it just goes on the vista...
Hello. Your battery or your charger is faulty. Take your laptop to any Staples store and have the computer tech. there take a look at it for you.
Nov 23, 2009 | Office Equipment & Supplies
The back cover of my Acer Extensa 5220 laptop is cracked
It would cost about $100-200 for parts.
That doesn't include the repair time. For me it would take about 10-15 minutes.
For a novice about 1-2 hours.
That's the jest of it.
New laptops $200-400 for decent rigs.
Jun 19, 2009 | Acer Extensa 503T Notebook
Acer aspire 5520 start up screen
can you go to bios? load default setings in bios, or optimized settings, then try... when something like that happens i usully pull out batery on mother board, than wait about few seconds and pul it back in... bu that is to much work. try above,, and let me know
Feb 15, 2009 | Acer Aspire 5520-5908 Notebook
Aspire 5610 stuck on initial Acer loading screen!
Time to re-install your OS.
Install Windows from Bootable CD.
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
