Question about Canon IMAGERUNNER 2230 Copier
E000024-0001 Canon ir 2230 - Canon IMAGERUNNER 2230 Copier
  • 113 Answers
The developing assembly connector may be disconnected.
Re-onnect the connector. If problem not solved replace the toner sensor.If issue not resolved replace your DC controller PCB
Posted on Jan 19, 2013
2 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: I have a problem with code ''E000007-0000'' (canon IR2230)
A E-000007-000 means that the fixing film in the fixing unit can not find the "Home Postion" for the film. Most likely the fixing film is ripped and the film has proble moved to one side. Basicly you are going to have to have the film adjusted back to HP or the film needs to be replaced. Have you seen any little pieces of thin Black plastic come out of the copier, also is the toner not bring fixed into the paper.... Good Luck..... You may need to call in for reinforcements to solve the code... It will not clear till it is repaired
Posted on Apr 28, 2009
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Cannon ir 2230 giving me an error code E000024-0001 what to do for this?
That means problem with toner sensor in developing assembly. Try cleaning it out, if it does not help try replacing the toner sensor itself.
Dec 22, 2016 | Canon IR 2230 COPIER FOR 220 VOLTS ONLY
Canon ir 2230 giving me an error E000024-0001 how to solve this porblem
That code means problem with toner sensor in developing assembly, try cleaning it out the best way u can, if that does not help you will probably need to replace toner sensor itself. (Toner Sensor FK2-0358)
I am using Canon IR 3530 the error code is E000024-0001 please help
I had the same problem on a IR-2230 and I had to replace the Developer Assembly. Check the connection first - have you recently had this worked on?
Mar 07, 2011 | Canon imageRUNNER 2000 Copier
Paper get jaming often.plz give mew solution
Some ir-2230 have an pressure problen on right lower door.
But check the pick up,feed,separation rollers, vertical path rollers,..... clean it, change it,...
Or send more detailed question-Why,when,how....
Oct 28, 2009 | Canon IMAGERUNNER 2230 Copier
152 people viewed this question
old marine
old marine
