Question about LaCie (300770) 250 GB Hard Drive
Hello, I have a Lacie 330770 250 GB hard drive.  It does not respond when I plug it into the outlet.  I have tried several different outlets in different rooms, and neither the green light on the power supply, or the blue light on the hard drive will turn on.  Any ideas what the problem may be?
If the green light on your LaCie power supply does not light, you likely have a bad power supply. You can buy a new one from LaCie. If you are purchasing a new power supply from LaCie ask for the higher wattage unit. LaCie upgraded this a while back.
Posted on Mar 20, 2009
When drive is switched on blue light on front flashes rapidly but the drive icon does not appear on the dektop.
Hello, the light blinking rapidly means that the drive is trying to establish communication with the computer but cannot.
First, check if the power brick is silent when plugged into the wall power outlet. If it is noisy, like hissing or high pitch noise, usually replacing it will solve the issue.
If the power supply seems healthy, it might be the port you are currently using, either on computer or drive side. Try using a different port on the computer, if no change, try using a different port on the drive. Using USB if connected firewire or using Firewire if connected USB.
If your drive is out of warranty, you can take out the internal hard drive and connect it directly to an internal port or put it in another enclosure to access your data, the internal hard drive should have no issue.
Regards,
Jan 11, 2011 | LaCie d2 Extreme (300793U) 500 GB Hard...
My iMac does not recognize the Lacie 1tb big disk extreme external hard drive. No icon appears.
the first step will be to verify your power supply. When it is plugged to the wall power outlet, it should be silent (no hissing or high pitch noise) and the green light should be on on the power supply.. If it is not the case, replacing it might solve your problems.
Second step is to verify if it is an interface problem. Try using a different port on the drive.
If no success, start Disk Utility and look to the left if you have any mention of a drive of 1TB. If you do, the partition of your drive might be corrupted. You can try running First Aid from Disk utility if its available, else you will need to try a partition repair software or a Data recovery program.
There are a few available that you can get a free copy to see if the data is available before you buy.
Regards,
Jan 07, 2011 | LaCie Big Disk Extreme with Triple...
Hello I bought a lacie hard drive model 301103U, my pc didn't recognize it because I can't to find the drive, I would like to have the drive for this deveice
Try connecting it to a different computer.
If it still is not detected, then it is "defective".
Take it back to where you bought it, and get them to repair/replace it, or for them to connect it to one of their computers, to "prove" that it works, at least some of the time.
Oct 23, 2010 | LaCie 301103U 500 GB USB 2.0 Hard Drive
My computer is not recongnizing my Lacie F.A. Porsche 250GB Hard Drive.I have tried to connect it to several computers.It also was making a wierd sound but it has stopped now.I can be emailed at chrls...
What operating system are you using? Is it windows XP or Vista? Or is it a mac?
If its under Windows, try to assign a different letter name to the drive. Go to My Computer, right click and then hit Disk Management. Locate the Lacie drive and then right click, and then choose Assign a letter name.
Let me know how it goes after you have done the steps above.
Dec 20, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My LaCie is not recognized by my computer, makes a clicking noise when it tries to start up. I've used this external hard drive for several years with no problems.
It has most probably just reached its "end of life". Several years for a hard drive reading and writing is a good track record.
You can probably take the casing apart and replace the hard drive. Just make sure that this is an USB 2.0 interface before spending the money.
Oct 20, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie external hd designed by f.a. porsch won't mount
I am sad to say that it's probable that this drive has failed. But if there is critical information on it, please unplug and discontinue use immediately.
You do stand a chance of recovering data if the drive has failed, but you lessen those chances as you continue to try to use it.
Definitely take this drive to a qualified repair outlet who can help with data recover if you need the information off of the drive.
Mar 20, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
I think I fried my LACIE 500gb drive
Sadly if you fried the drive with that PSU cord it would be pretty hard for a home repair. If you know its definatly dead, I would just remove the drive from the external unit and try to connect it internally to a computer. If the adaptor is different you could buy a cheapy online somewhere.
Jun 18, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie (300770) 250 GB Hard Drive Logo
613 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
