Washing machine inside drum is off center in a big way and seems to be off the base completely. Please help and thank you in advance.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
Ist sure caused by heavy loads... in the center you will find a bolt or nut... remove it to check which feet of the motor are destroyed... unrust and weld it together...
or
you can bring the motor in a service center or replace a compatible one...
Posted on Jan 19, 2013
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
  • 1314 Answers
SOURCE: Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Posted on Feb 16, 2008
  • 43 Answers
SOURCE: zanussi washing machine drum will not go round at all
Tracy
The bearing may have siezed or you have something jammed between the drum and outercasing
Posted on Mar 23, 2008
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Posted on Apr 23, 2008
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Posted on Jun 27, 2009
My elite drum is not centered and is rotating off center, see additional details please, thanks.
probably need drum or bearing support rods
contact your local authorized service agent for parts
Jun 24, 2017 | Washing Machines
Hi, i have a haier AA 6kg washing machine, and the glass door is being rubbed by the metal drum inside causing it to spark inside the machine and mark all my washing, how do i fix this problem? is it the...
The cost depends a lot on the location you are in but not to worry this seems to be a mechanical fault and all what is required is good skill to remove the assembly and check , replace the bearings, check the shaft, bushes, seals for wear and reset.
With a manual check you can observe the wobbling of the drum and will prove that this is not steady due to the failure of the mechanical system comprising the spares mentioned.
Apr 01, 2011 | Washing Machines
Our Frigidaire FEX831CS dryer started making funny noises and has completely stopped. We hit the start button now and all we hear is is humming in the machine. We checked the belt and it does not seem...
Check the inside rear of the drum for the three screws in a triangle closest to the center.
If these screws come out the drum rolls off center and the motor can no longer drive it.
Good Luck
Quentin
Oct 11, 2009 | Frigidaire FEX831CS Top Load Stacked...
I have two socks inside my drum in my washing machine
They are probably wrapped around the heater element or laying in the sump that the heater sits in.
When you said you have removed the hose did you remove it from the pump end or the drum end.
The drum end should allow you to get a torch and a small mirror to take a look inside the base of the drum.
If you can see something then you are home and dry if not then:
Use a wire coat hanger and form a small 90 degree bend in the end say 18mm, dont make it too big in case it fouls on the heater.
Use that to probe along the bottom of the inside of the drum
If you can feel something soft turn the wire a couple of times to engage it in the cloth and try to pull ut out.
If it wont come out then the only solution is to remove the heater element to gain access
May 27, 2009 | Washing Machines
Need schematic diagram of the washing machine assembly
A mechanical assembly diagram would have to be requested directly from LG.
May 18, 2017 | Washing Machines
Whirlpool Front Load Washing Machine is very Noisy when spin
if it make noise like a train coming in on track,,,bad tub bearing,,,do you see any water leaks back there ..on the back tub or on the base of unit...if so seal damage,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Funny noise when machine is emptying
Does the "whirring noise" sound like a jet engine?  If so your bearings are going.  Check your warranty.  It's a big job to replace them.
Oct 06, 2007 | Summit Commercial SPW-1100 Front Load...
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
