My top load washer stays off balance.
No matter how I arrange the items being washed the unit stays off balance. I have to rearrange the clothes several. This did not happen when I first purchased this washer.
  • twilham09 Mar 08, 2009
    we moved our front loading ge washer and it spins and washes off balance. how do i fix this?
  • 2,920 Answers
One or 2 of the springs under the tub are worn out or broken loose
Posted on Jan 26, 2009
My washing machine does not spin the clothes dry-clothes are soggy
Was your load a single item or many over full. Many washer will quit so you can rearrange the items so it can spin balanced. The machine will try 10 times to balance the load , if it can;t do it it turns off and waits for you to do it.
Mar 14, 2015 | Maytag Washing Machines
Why does the UE come on ,on the cleaning cycle
The UE error or fault code indicates that the load of clothes is unbalanced. Try rearranging the clothes. Also, if you are only washing a few items, you may need to add a few more to allow the tub to balance. Also, check to be sure the machine is level and that all four feet are touching the floor. Tighten the locking nuts on the feet to lock them into place. If that doesn't seem to be the problem, either the suspension rods or shock absorbers may be broken or worn out.
Aug 25, 2014 | LG WT5101HV 4.5. CU. FT. ULTRA CAPACITY...
Banging loudly on spin cycle . machine is leveled and clothes are equally distributed
Machine is level but the load isn't.rearrange the clothes to balance the weight in the machine.
Dec 14, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Comes up with the sign UE ??
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Sep 09, 2009 | LG WM-2277HW Front Load Washer
It shows uL and wont drain
Unbalanced Load - open the unit and re-arrange the clothes.
If they are balanced - the balance sensor should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
and the error code will be
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Whirlpool Calypso
This could be an out of balance condition. When its happened to my washer, I rearrange the load if its large enough, and if its not, I find other items of like weight and add them to the load and start over. Calypso's are sensitive to fabric weight, so If you're washing towels, wash only towels and wash cloths. Make sure you put small items, like bras, panties, nighties, etc., in mesh bags and combine them with other light weight fabrics.
Aug 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Cloths were soaked !Won't restart, door locks and you hear a buzzind sound ??
Greetings JohnnyWrench,
Information provided by the manufacturer would indicate a few things possibly causing this:
1) Washer was overloaded, remove some of the clothes and continue the cycle.
2) Washer load was too small. Add 1 or 2 similiar items to help balance the load.
3) Load is out of balance, rearrange clothes to allow for more balanced spin.
4) Drain hose might be kinked, straighten drain hose.
You can also find a copy of your owners manual at
I hope some of this helps!
Thank you,
Go Ahead. Use Us.
Apr 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
