Question about Hunter Fan Company 7-day programmable thermostat
Old LR69071 po new RTH7600D honeywell temostat
Install and wire
2 Suggested Answers
  • 98 Answers
SOURCE: The Honeywell LR69071 (old) has 7 wires connected
Wiring on the old one, "X", probably a brown wire will not be used on the new stat. If it's a blue wire, this may be your common. "E" and "W2" probably wired together with a white wire, this controls electric heat. "R" with a red wire, this is 24 volt power. "O" is an orange wire, this is the reversing valve. "Y" is a yellow wire, this is the contactor. "G" is a green wire, this is the blower. This pretty accurate? On the new stat, the jumper should be connecting "RH" to "RC/R", leave it in and wire the "R" from your old one to either terminal. White from the old one will go to the "E" of the new one. If your electric heat doesn't work after the install, you may need to jumper the "W1" and "W2" with the "E". "O" wires to "O". "Y" from the old one wires to the "Y1" of the new. "G" wires to "G". "C" on the new one is common. Usually a blue wire goes here. If "X" on the old one was blue, plug it into the "C". If it was brown, I'd suggest not using a common, and installing batteries. Hope this helps.
Posted on May 09, 2010
I need to install a car alarm into my 1998 mazda metro and need the wiring diagram for the wires under the steering wheel.
Most aftermarket car alarm manufacturers have support diagrams on their website to assist in identifying the correct wires to install their device. Be advised, if you are not very skilled at electrical installations (and installing a simple car radio don't count), you may be biting off more than you can chew. There is potential for serious damage and/or injury with the wiring under the dash as much of it runs high current. Short something out or connect to the wrong wire(s) and you might be out of a car. I personally have a fair amount of skill in electronics and wiring systems. I have installed five remote start/alarm systems and never had one that I could say went easy. Either the wires are hard to find/access, or there is virtually no room under the dash for the associated electronics that go with the install. Be prepared for a project that can last days.
Aug 31, 2016 | Mazda Cars & Trucks
How to install Pyle radio PLR31MP
remove factory radio ,if you dont have the special tool to do this you can use coat hangers but I perfer using the factory tool sold at wallmart (the cheepest) or autozone push tools into holes on both ends of radio pull radio out. disconect wireing harnes and antenna wire.To install new radio you will need a wireing adaptor and a install kit. These must be spasific to your vehicle. you can buy these online Ebay , or Amazon or off line wallmart or orillys auto parts you will have to connect your new radio wiring harness to wiring adaptor.put install kit on new radio attach antenna wire connect wireing adaptor to original radio wiring push radio gently back into dash with install kit attached. enjoy your new radio. if this was helpful please leave good feed back.
Jan 03, 2015 | 1998 Ford Ranger
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Installing a light dimmer switch and ceiling fan power but when replacing the old switch I see only two wires hooked up plus not all the same colors need help choosing the right ones
I know that in your wall you have your two primary wires of black and white. Black is you HOT wire so please be careful with it and your white wire is you COLD wire. The green wire is primarily used as the GROUND wire. I have a couple of questions for you. 1) what is the make and model of the fan of which you are installing? 2) Dose this fan that you are installing have a remote that is connected to it? 3) How many wires are connected to the fan of which you are installing?
Mar 09, 2013 | Dryers
When installing mt kenwood kdc x696 the wires on the deck do not match the wires on the install
Sometimes you have to ignore the color codes and match by function, i.e., right front speaker wires on the deck to right front speaker wires on the install, etc.
Jan 08, 2013 | Kenwood KDC-X696 CD/MP3 Receiver with USB...
Describe your how fix my pontiac 2000 montana Problem changing spark plugs
Inspection
Inspect for the correct routing of the spark plug wires. Improper routing may cause cross-firing. Inspect each wire for any signs of cranks or splits in the wire. Inspect each plug wire boot for tearing, piercing, arcing, carbon tracking or a corroded terminal.
If there is any corrosion, carbon tracking or arcing indicated on a plug wire boot or terminal, both the plug wire and component it was connected to should be replaced.
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the left side spark plug wires from the spark plugs.
  3. Remove the left side plug wires from the retaining clips.
  4. Rotate the engine for access as follows:
    1. Set the parking brake.
    2. Shift the transaxle into neutral.
    3. Remove the engine mount strut bolts. Swing the engine mount struts aside.
    4. Install the Engine Tilt Strap J-41131.
    5. Pull on the engine in order to rotate the engine forward.
    6. Tighten the strap.
  5. Remove the right side spark plug wires from the spark plugs.
  6. Remove the plug wires from the retaining clip.
  7. Remove the spark wires from the ignition coils.
  8. Remove the plug wire assembly from the engine.
    NOTE If you are replacing the spark plug wires, the spark plug wire conduit and retaining clips should be transferred to the replacement wires.
To install:
  1. Install the right side plug wires to the ignition coils and then the spark plugs.
  2. Install the spark plug wires to the retaining clip.
  3. Rotate the engine back to the original position.
  4. Install the left side spark plug wires to the ignition coils and then to the spark plugs.
  5. Install the spark plug wires to the retaining clips.
3.9L Engine
  2. Remove the intake manifold cover.
  3. Remove the left side spark plug wires as follows:
    1. Disconnect the left side spark plug wires from the spark plugs.
    2. Disconnect the left side spark plug wires from the ignition coil.
    3. Remove the left side spark plug wire clips from the intake manifold and heater inlet and outlet pipe.
    4. Remove the left side spark plug wire assembly.
  4. If removing the right side spark plug wires, the engine must be rotated for access as follows:
  5. After rotating the engine, remove the right side spark plug wires as follows:
    1. Disconnect the right side spark plug wires from the spark plugs and ignition coil.
  6. Remove the right side spark plug wire clip from the ignition coil bracket.
  7. Remove the right side spark plug wire assembly.
To install:
  1. Install the spark plug wire assembly.
  2. Install the right side spark plug wire clip at the ignition coil bracket.
  3. Connect the plug wires to the ignition coil and spark plugs.
  4. If the engine was rotated for access, return the engine to the original position.
  5. The remainder of the installation is the reverse order of removal.
Feb 05, 2011 | 2000 Pontiac Montana
How do I replace the ignition coil in my 2002 ford taurus
3.0L (VIN S) Engine
  1. Disconnect the negative battery cable.
  2. Unplug the engine control sensor wiring connectors from the ignition coil and the radio ignition interference capacitor.
  3. Tag and disconnect the spark plug wires from the coil by squeezing the locking tabs, then twist the tab and pull upwards.
  4. Unfasten the four ignition coil retainers and remove the coil and the coil ground wire the radio ignition interference capacitor. Save the capacitor and coil ground wire for re-installation of the coil assembly.
  5. Wipe the coil towers with a clean cloth dampened with soap and water. Remove any soap film and dry with compressed air. Inspect the coil for cracks, carbon tracking, dirt or damage and replace as necessary.
    Fig. Ignition coil assembly mounting-3.0L DOHC engines
To install:
  1. Place the coil, capacitor and the coil ground wire onto its mounting location on the right hand valve cover.
  2. Install the coil assembly retainers and tighten to 45-61 inch lbs. (5-7 Nm)..
  3. Apply dielectric compound D7AZ-19A331-A or its equivalent to the spark plug wire boots.
  4. Attach the spark plug wires to their proper terminals on the coil and make sure the boots are firmly seated so that the locking tabs engage.
  5. Attach the engine control wiring connectors to the ignition coil and the radio ignition interference capacitor.
  6. Connect the negative battery cable, start the vehicle and check for proper operation.
Dec 19, 2010 | 2002 Ford Taurus
Four wires wrapped as two
Yes...just keep the four wires wrapped as two and then hook up as a two wire connection...
The two wires wrapped together just makes it work better if the wires are a bit too light...
The two wires wrapped together will function as one wire...
heatman101
May 06, 2010 | Hunter Fan Company 5/1/1 Programmable...
HOW DO I MAKE SURE I HAVE THE RIGHT SPARK PLUG WIRES GOING TO THE RIGHT CYLINDER
Are you going to install plug wires or you already have them installed and the engine is not running right?
If you're going to install them, the key is to do them one at a time. Take a wire loose, measure its length against the new wires, choose the closest match, and install the new one. Follow the same procedure with the other wires.
If you've already installed them, you will have to find a diagram that shows which distributor connection point is for which plug wire and match that to the correct cylinder. You could probably find that in a Chilton or Haynes repair manual.
Oct 15, 2009 | 1995 Cadillac DeVille
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
Hunter Fan Company 7-day programmable thermostat Logo
42 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
