thank you. you do not know the headache he has caused me.thank you. you do not know the headache he has caused me.
AnonymousFeb 21, 2008
my tv was hooked up with a video phone 200 and I need to have the video showing in order to make calls. The channel is on 2 and will not change.
Thanks!my tv was hooked up with a video phone 200 and I need to have the video showing in order to make calls. The channel is on 2 and will not change.
Thanks!
My son has a Duraband 25 inch, it's showing a black screen and has the word video on the upper right of the screen it wont change stations and the orignal remote is broken. I've tried to use a universal remote but it won't work. any ideas or solutions would help alot.
[email protected]My son has a Duraband 25 inch, it's showing a black screen and has the word video on the upper right of the screen it wont change stations and the orignal remote is broken. I've tried to use a universal remote but it won't work. any ideas or solutions would help alot. [email protected]
You can't post conmments that contain an email address.
For GE televisions, press and hold the "1" button on the remote. The input display in the upper right corner will change from two-digit mode ("1 -") to three-digit mode ("1 - -"). You can then enter the final two digits for the channel you want.
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one...The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
You have to go through the set up guide and reset the information you put in. It may have changed. Afterwards you must run through the auto program. This is a common problem i find with customers.
the tac switches have gone bad.this happens from age or sometimes from washing the screen of the set and moisture gets on the.. it is not a big job but it does involve soldering skills
Thanks!
[email protected]
