Question about Binatone Lands Phones
Binatone concept 3505 no dialing tone
Base unit says line in ue when you pick up the receiver & there`Dialing tone
4 Suggested Answers
SOURCE: Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Posted on Jan 23, 2009
SOURCE: KX-TGA110FX
1.Press (ok)
2.Arrow down(twice) to "setting BS" then right
3. Input PIN code.Usualy 0000
4.Press "1"if you want TONE dialing or "2" for PULS
5.Press right arrow,then on/off button
Posted on Mar 12, 2009
carlsbiz
  • 1124 Answers
SOURCE: Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Posted on Sep 17, 2009
How do i stop my binatone home phone diverting my callst a .i can not get get a dialing tone.
Do other phones that are plugged into the phone jack get a dial tone? If not then you need to call your phone service provider, if other phones work and just this one has the problem then the phone's base station is defective. In that case the phone is replaced as the cheapest fix
Aug 18, 2016 | Binatone Lands Phones
Please help I can't ring out on my phone
Check for dialing tone by pressing 'Talk On' phone button.
If no tone, check cord at base station and the phone socket is correctly plugged in at both ends using the original cord supplied.
If still no dial tone, check the phone at another phone connection to establish if either the phone or the line is faulty. Address for
Binatone support at this link: http://binatoneglobal.com/support/
Jun 28, 2015 | Binatone Lifestyle 1910 Twin Cordless...
Selecting dialing mode
The directions for changing the dialing mode from tone to pulse can be found in the owner's manual for the main base unit.
Press the [MENU] button then choose "Set tel line". Then choose "Set dial mode", then choose Pulse or Tone and press [OK].
Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF#page=14
Jun 28, 2014 | Panasonic KX-TGA101S Cordless Handset
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
One of my phone is stuck in search mode what do i do it i a vtech 6772.It is a three phone combo other two phones work fine
HI, To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
thank you,
vijay
Sep 29, 2009 | Vtech Two Line Digital Answering Machine...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Feb 24, 2009 | Uniden DECT 6.0 Cordless Telephone...
Oct 25, 2008 | Vtech 2467 Cordless Phone
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
Lands Phones Logo
44 people viewed this question
Top Binatone Lands Phones Experts
ray gallant
AJMAL KHAN
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
