Question about Memorex MEM48U Flatbed Scanner
I hae a memorex 6142u w/ no vista drivers???
How do i make this work with vista
After searching the visioneer.com support website, I found an article at: http://support.visioneer.com/KnowledgeBase/Articles/VIS1493%20-%20Updating%20Your%20Scanner%20Driver.asp?ScannerModel=X2400&bit=64
Download the latest driver - it is for a Xerox 2400 Scanner. This driver works for a Memorex 6142u scanner.
Do the advanced install where you pick the type/brand of device that you want to install
Pick the location of the driver file (C:\Windows\inf) This should pick up the oem76.inf file.
Scroll down the list to the Xerox devices and pick the Xerox 2400 scanner. Click yes, that you want this driver/device even if Windows is not sure that tihs driver works with your hardware.
This worked for me.
I did try installing the XP drivers from http://support.visioneer.com/products/6136/default.asp I set the file properties to Windows XP Service Pack 2 mode first. But that did not work for me. I also read that some Canon driver would work, but I could not seem to get that working.
So download and install the Xerox 2400 Scanner driver and manually add that scanner in the device driver and you'll be all set. I'm using Vista Home Premium 64 bit.
-Alexei
Posted on Nov 14, 2009
  • 684 Answers
Go to site http://support.visioneer.com/products/home/EOL/Memorex/
Download/save application file 6142. Check file properties, under compatibility select "run this program..." and choose Windows XP(Service Pack 2). if u do not have a vista option
Then run the program.
Good Luck
Posted on Jan 26, 2009
3 Suggested Answers
SOURCE: i have a memorex 6142u w/ no vista drivers???
I'm running a 6142 on Vista using the Memorex driver. I didn't think about it when I got Vista, I loaded it up and everything works fine. I've been using it for sometime with no problems. I installed it using the Memorex CD and have had no problems.
Posted on Feb 01, 2009
This solution worked for me. I have 64-bit version of Vista. If you have 64-bit version of Vista this is the only thing that I have found to work.
What I did was used a different scanners driver for my Memorex 6142u. I used the Hamrick version of the Canon N1220U scanner driver. The best way to do this is to plug the USB cord into the computer. Vista will try and find the driver for you and fail. then go to device manager. It will say that it isn't working properly. Then fix the driver by selecting from the list of drivers that Vista has packaged with it.
Posted on Sep 12, 2009
Needsofware & drivers for vista
Hello try the driver from here:
Try installing the driver in compatiblity mode.
I could not find the driver for vista.
Good luck
Jan 01, 2013 | Memorex FU661E 6142u USB Flatbed Scanner
Is there a driver for a memorex scanner 6142u for a visa operation system??
Try this liks :
  1. Memorex Scanners drivers - [ Traducir esta página ] Memorex Scanners drivers. Here are drivers for 7 models of Memorex Scanners. Driverscollection.com - One of largest free net library of device drivers for ...
    driverscollection.com/?V=Memorex&S=14 - En caché - Similares
  2. Memorex Scanner Drivers - [ Traducir esta página ] (Category: Scanner / Firm: Memorex / OS: Windows 95/98/ME/NT/2000/XP). 2. Memorex 6142U · Driver Download. (Category: Scanner / Firm: Memorex / OS: Windows ...
    www.driverskit.com/Scanner/Memorex.html - En caché - Similares
  3. Memorex Scanners Descargar de drivers Este sitio mantiene la lista de Memorex Scanners Los drivers accesibles para Descarga gratuita. Nada más que rastree nuestra base de datos organizada y ...
    www.nodevice.es/driver/.../Memorex/Scanner.html - En caché - Similares
Oct 03, 2010 | Memorex MEM48U Flatbed Scanner
What is the voltage of the 6142u scanner (lost my power supply)
http://www.memorex.com/archives/downloads/manuals/6142Scanner.pdf
Check the last page of the document, and you'll see all of the specs you need.
Good luck.
Jul 01, 2010 | Memorex MEM48U Flatbed Scanner
Need drivers for a memorex 6142 usb scanner for the windows home vista program.
http://www.opendrivers.com/driver/215409/memorex-6142u-scanner-driver-windows-98-me-2000-xp-free-download.html try driver from windows 2000
otherwise no drivers availebel
Aug 24, 2009 | Office Equipment & Supplies
I have a memorex 6142u w/ no vista drivers???
Jan 26, 2009 | Memorex MEM48U Flatbed Scanner
Powder Cord for Memorex 6142u scanner
The manual is available online at http://www.memorex.com/downloads/manuals/6142Scanner.pdf
The back page has the specifications for what kind of power cord you need, depending on what country you live in. The US one at least (120V/60Hz) is a very generic cord option and should be easy to find at any tech store. Good luck.
Jul 31, 2008 | Memorex MEM48U Flatbed Scanner
I have a Memorex U48 Flat Bed Scanner and have bought a new compouter with Vista. I need a driver download to work with Windows Vista. Thanks jreowens@aol.com
get the winXP driver MEMu1.50 (still available), there are no Vista drivers. Run the installation using WinXP emulation in Vista. You must run the installation as if you are in XP, not necessary when using the scanner subsequently. Now the Memorex 48u works on a Dell Dimension, running Windows Vista Home Premium. Hope this helps. I got the scannner for $14 after rebates at Staples years ago, it won't die.
May 05, 2008 | Memorex MEM48U Flatbed Scanner
Memorex MEM48U Flatbed Scanner Logo
2,249 people viewed this question
Top Memorex Office Equipment & Supplies Experts
ray gallant
Are you a Memorex Office Equipment and Supply Expert? Answer questions, earn points and help others
