Question about Numark NS7FX Motorized DJ Software Performance Controller
Can't calibrate ns7
It won't let me calibrate it only flashes the 1 on the left deck
Ns7 II playback slow anyone else having this issue?
I have this problem some times with right deck with some videos or song
May 06, 2014 | Numark NS7FX Motorized DJ Software...
Ns7 freezes or auto update firmware
Joshua's answer has nothing to do with your problem.
Jan 20, 2014 | Numark Industries Numark NS7 Numark...
Cassette stuck in left side, won't eject
The mechanism transport need work to allow the unit to get back to the stop/Eject cam position. Without that the deck is not going to work. This is usually but not always due to a small rubber belt. That is not all that is needed but the primary reason for that failure.
Jan 14, 2013 | Audio Players & Recorders
Landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
May 08, 2012 | Landice L7 Executive Trainer Treadmill...
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
I have a Stanley IntelliSensor Pro. It's worked fine for a couple of months. Now it won't calibrate - it just flashes quickly calibrating, and alternatively flashing the centre (bullseye) ci
I hate to tell you this as you are an electrician but often it is best to look for the simple solution. My Stanley IntelliSensor Pro was doing the same thing here is the answer:
CHANGE THE BATTERY
Apr 26, 2012 | Cars & Trucks
My ultrafit treadmill won't run-the control panel
2_15_2012_4_45_37_pm.gifAdjust the reed switch as indicated by the diagram by 1/8- 1/4". Run the calibration software instruction under the Hood motor or see your user manual.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
Numark NS7FX Motorized DJ Software Performance Controller Logo
79 people viewed this question
Top Numark Computers & Internet Experts
Mike
aravind shet
aravind shet
Are you a Numark Computer and Internet Expert? Answer questions, earn points and help others
