Question about Apple iPod touch 1st Generation (8 GB) MP3 Player
How do I fix my frozen e reader
The off on switch not working for awhile ,I was starting it by connecting to computer and then cancelling when it turned on. Now it is frozen on a search page.What do I do?
  • Apple Master
  • 27,725 Answers
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Posted on Jan 20, 2013
SOURCE:
Tip
Sony Reader Frozen
This solution applies for issues with Sony Reader Frozen in any model. PRS500, PRS505, PRS700, PRS600, PRS300, PRS900, PRS350, PRS650 and PRS950.<br /><br />1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer<br /><br />2. Hit the reset button for 3 seconds.<br />Location of RESET button:<br /><br />On the back = PRS500 - PRS505 - PRS 700<br />At the bottom: All the other models<br /><br />3. The red steady light should come on, if not, try the reset again while the unit is connected<br /><br />4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.<br /><br />5. Disconnect the reader and see if operational.<br /><br />GoodLuck!<br /><br />eBookBoy<br />
on Jul 11, 2011 | Computers & Internet
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
My sony ereader prs-650 is stuck on sleep mode and it wont do anything ,, it wont charge when connected to the computer
Each step in my solution is a possible resolution. Hence I suggest that you perform each step and check the operation.
Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to display the charging symbol if the Reader is fully drained in its last use.
Perform a soft reset. We can perform a soft reset by pressing the reset button on the Reader.
After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light next to the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptor and then press the reset button.
Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Reader device. Check if the Indicator light next to the power switch on the Reader device is yellow (indicating it is turning on) and if the unit is responding
If the unit is still frozen, connect it again to the computer or AC adapter and while connected, check if the Indicator light next to the power switch on the Reader device is red . If this light is red , allow the Reader device to charge for one hour so there is sufficient charge for troubleshooting.
Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader device between temperature extremes or if the Reader device has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader device to sit for a few hours before attempting to turn it back on
Jan 12, 2011 | Sony Reader Touch PRS-600
How do I get my memory card to work. It says "card protected"
Some memory cards have a Write Protection switch on them.
To check this please remove the Memory card from the camera. Check if there is a "lock" switch on the left side.
Slide this switch to the "Unlocked" position, and reinsert the card into the camera.
This should resolve the issue and the error should go away.
In case the issue persists, it could mean the the write protect on this card was perhaps set by mistake while it was connected to the computer.
You will need to use the computer to cancel the read-only setting.
Please connect the card to your computer through the camera or a card reader and cancel the write protect on the card.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating.
Sep 26, 2010 | Vivitar Cameras
Sony PSR 300 e-reader frozen screen
since you've tried charging the reader using a non-compatible charger, there might be some internal malfunction occurred in the reader. however, i suggest that you try charging it by connecting it toi the computer. as the yellow ligjht is is blinking, it seems that there is no chrage in the reader. so try charging it by connecting it toi the computer.keep it connected for at least 4 hours. it should resolve the issue.
Jan 28, 2010 | Sony E-reader Portable E-book MP3 Player
My sony reader is frozen. I cvharged it
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred.
Please perform the below mentioned steps and check whether it helps.
Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure.
2. Perform a soft reset. Just press the RESET button using a sharp-pointed object
3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again.
5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding.
6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset.
7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off.
* It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E.
8. Once the Reader has sufficient charge, perform these troubleshooting steps again.
9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status:
* You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged.
* It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired:
http://eservice.sony.com
Jan 20, 2010 | Sony E-reader Portable E-book MP3 Player
The USB connected screen is frozen on my reader and I don't know how to fix it.
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred. Please perform the below mentioned steps and check whether it helps. Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure. 2. Perform a soft reset. Just press the RESET button using a sharp-pointed object 3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup. 4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again. 5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding. 6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset. 7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off. * It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E. 8. Once the Reader has sufficient charge, perform these troubleshooting steps again. 9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status: * You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged. * It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired: http://eservice.sony.com
Jan 02, 2010 | Sony Reader Touch PRS-600
My reader's menu is frozen and it wont respond to any buttons. How do I fix it?
Nov 17, 2009 | Sony E-reader Portable E-book MP3 Player
Copying files to the computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Apple iPod touch 1st Generation (8 GB) MP3 Player Logo
98 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Jeffrey Groves
Jeffrey Groves
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
