When I turn it on the caps light flashes 10 times then it turns off I've changed the ram chip but still nothing
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Hearing beeps...?
Posted on Jan 19, 2013
Joed911
  • 4338 Answers
SOURCE: New Board; Fan turns on; No Screen; Cap, Scroll, Num lights flash
Great!
I've been bitten by that, especially on Dell laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 06, 2009
geo_jonas
  • 555 Answers
SOURCE: My dell latitude c 640 will not start up. When
Please check your battery and power source to ensure that power is not the cause of your problem. Then after you check please try to find a computer technician in your place or a computer shop and let them fix for your problem or contact your supplier to ask for help especially in your problem.
Thanks
Posted on Aug 24, 2009
Temab
  • 257 Answers
SOURCE: toshiba satelite a105-s171 is dead, later than I
try changing and reloading the hard disk ok
Posted on Mar 01, 2010
computus
  • 487 Answers
SOURCE: Just bought 1 gb of ram for dell b130. When i turn
When installing new memory it is vital only touching on the outer edges of the memory. saying that, carefully take out the memory card and re install
Posted on Jul 04, 2010
  • 68 Answers
SOURCE: My toshiba satellite a205 will
If it does the same thing w/ the battery removed and just on AC, it's a power regulator problem on the motherboard. If it works with the battery out, the battery is dead and you need a new one.
Posted on Jun 30, 2011
My 1998 buick century 3.1 will not start. I changed starter , I changed the ignition switch , I even jumped the battery to starter with a push button , It now will turn or crank , but ,, it still will not...
THERE IS A CHIP IN THE KEY I BELIEVE. THERE IS A RELEARN PROCEDURE YOU CAN TRY IF WHEN YOU TRY AND START IT THE SECURITY LIGHT FLASHES. HOOK UP A BATTERY CHARGER. TURN THE KEY ON AND TRY AND START THE CAR AND RELEASE . DO NOT TURN KEY OFF LEAVE IT IN THE RUN POSITION. AFTER 10 MINS THE LIGHT WILL STOP FLASHING. TURN KEY OFF. TRY AND RESTART CAR AND AGAIN DO NOT TURN KEY OFF LEAVE IN THE RUN POSITION. LET SET 10 MINS AGAIN. LIGHT WILL STOP FLASHING AFTER THAT 10 MINS. DO IT AGAIN FOR THE 3RD TIME. SHUT KEY OFF LET SET 5 SECONDS AND START THE VEHICLE. HOPE THIS HELPS
Feb 22, 2013 | 1997 Buick Century
Ram slots problems
Are you sure it's the slot and not the ram? Try switching the ram to isolate which memory chip is bad. You can start by using on ram and one slot, then booting and if it's ok, move it to the next slot and boot. Once you've tested that one memory chip, do the same thing with the other memory chip. More than likely you've got a bad memory chip.
Try switching the ram in each slot. If switching them around does not solve the problem and your slot is truely bad, you will have to replace the motherboard or increase the size of the ram in the slot that works.
May 23, 2012 | Dell Optiplex GX280 Intel Desktop PC -...
My M4N68T-M V2 won't boot for the first time. I am not sure if speaker works but with just ram chip the chip fan turns a quarter turn when i push power button and the power light flashes. No ram nothing...
i think the main problem is your power supply, maybe not enough power to make boot.. try another power supply with high voltage.. hope this useful, regard riyan.
Mar 29, 2011 | Computers & Internet
Lightbulb is red and flashing next to turn on switch. What is the cause?
Could be a number of things. Usually a hardware problem Try:
-removing and reseating the RAM chips, test, if no good, try
-remove one RAM chip, test, if no good, try
-unplugging all components (hard drives, CD/DVD drives, floppy...anything that consumes power), test, if no good, try
-letting the system sit for 10 minutes, powered off too cool down, test, if no good, try
-a different CPU, test, if no good, try
-a different motherboard
If any of the above steps gives you a different result than the flashing red light, then the offending part has been removed from the test equation.
-Reseating the RAM can fix thermal creep
-If you have one bad RAM chip out of multiple chips, removing and replacing them one at a time can show which chip may be bad.
-If a drive/component is bad, removing that component can allow the computer to boot
-Heat can cause component failure or erratic behavior (no boot, etc)
-A failed CPU can prevent boot or POST
-A failed motherboard can prevent boot or POST.
Best of luck!
--JK
Mar 03, 2011 | HP Compaq d530 SFF PC Desktop
Everytime I turn on my D410 Dell Laptop, the screen doesn't turn on. The caps blink about 10 times then shuts down. Please help?):
The flashing caps lock light indicates an SDRAM memory fault. If you are comfortable accessing the RAM yourself you can try re-seating it and see if that fixes the problem. If that does not work or you do not want to open the laptop up yourself, you will need to have the RAM replaced.
Mar 01, 2011 | Dell laptop Latitude D410 Series with...
I drove the car to my mothers yesterday, went to my dads got there just finr. We went to leave and the car won't start turn over nothing. The security light is flashing. My dad could get it to start from...
you need to get a new ign. lock cylinder and chip key. Or you can get a lock cylinder and copy your old key with a regular key no chip. Take new cylinder, put old chip key in it. Plug into harness at the bottom of steering column just behind the dash, fine orange wire from existing one in the column. Hide lock cylinder under dash and start car with copy of old key.
Dec 26, 2010 | 1991 Buick Park Avenue
I just change my battery in an 05 grad pre. it still will not start i;ve had it say security issuses, but now there nothing that says that. it just clicks
if you changed the battery and it just clicks , must likely is a bad starter,.. now if its cranks and won't run and the security light states flashing, then it could be a security problem...you will need to open the ignition and let the light flashing for 10 min , when the light turn off , close the ignition , and turn on again, do this three time..
Jul 27, 2009 | 2000 Pontiac Grand Am GT
Inspiron 6400 doesn't start.
On Flash Flash indicates that no RAM memory is being detected. So remove both RAM modules, insert 1 at a 30 deg angle till the gold contacts cannot be seen, then lock it in place, and see if the RAM is detected. Test both modules in both slots, see if system will boot with at least one. If no change, try a new RAM module, if still no change, replace the motherboard
Jul 04, 2009 | Dell Inspiron 6400 Notebook
No Lights On But Fans On
I would start by using only 1 stick of RAM this sounds like symptom of a failing ram card or occasionally ram socket. The RAM is on the bottom of the laptop under the middle panel.
If you have 2 chips try each chip individually in each socket.
If it was turning itself off it was probably overheating - i see the fans gets clogged on this series all the time. You may want to blow it out with a can of compressed air.
Let us know if you need more help.
Oct 11, 2007 | HP Business Notebook NX9110 Notebook
Computers & Internet Logo
David Payne
David Payne
