Question about Nintendo Wii Video Game Consoles & Games
Electric shock from an unplugged Nintendo wii - how is this possible
My husband was sorting out the power cables from our Nintendo WII when he received an electric shock from it. It was neither plugged into the wall or the console. Can anyone explain how this could have happened as the console had been unplugged for months.
  • 33 Answers
It was probably just static electricity. Sometimes the body build up static electricity by just walking on a carpet or from friction of the clothes being worn. He then got the shock when he somehow grounded himself.
Posted on Jan 20, 2013
lukeyman
  • 43 Answers
SOURCE: make nintendo wii multi region
also, if the games you want to play are copied, like $5 games from asia, you will need a modchip to be installed in your console. if they are licensed real copies, you can buy a datel freeloader to make your wii region free
Posted on Sep 14, 2008
SOURCE: nintendo wii wont turn on
try using a new outlet thing adn it might work BUT!!!! i have never tryed it yet. i'm sure it will work because the main cause is the power outlet. so buy a new one.
Posted on Dec 12, 2008
  • 5 Answers
SOURCE: 2 discs in stuck in nintendo wii console
asdfds
Posted on Mar 21, 2009
Danster5oo
  • 123 Answers
SOURCE: can we play gamecubegames inside the wii console, if so how?
You can do both. With internet you can download Nintendo 64 games on the wii shop channel. For game cube games enter the controller in slot one, enter the game and it's like you don't have a wii!
Note: due to the fact the the wii remote does not have enough buttons ALL N-64 games need a gamecube controller or a classical controller. Game Cube games are not compatible with classical controllers.
Posted on Apr 16, 2009
SOURCE: power surge and wii console
By switching it to another outlet. It came back on.So replugged in the first one and it's working now.
Posted on Jun 03, 2009
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
May 05, 2011 | Nintendo Wii Console
Tip
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
I hope this tip helps!
on Apr 09, 2010 | Video Game Consoles & Games
I accidentally set my wii to HDTV settings and I need to reset it back to normal tv but my screen is so messed up I cant see options or anything
May 01, 2011 | Nintendo Wii Console
Wii stopped working. the light is not on. There is a disk inside that won't eject. We tried unplugging and replugging everything. Could it just be the 3V battery ?
did the power go out while your Wii was plugged up and on or in sleep mode? if it was, you probably need to unplug you wii from everything and let it sit for a few minutes. your Wii probably just got 'shocked' by the sudden lack of a power source. If the power didnt go out, then I dont know how to help you~ Sorry. I hope I helped!! ^-^
Oct 02, 2010 | Nintendo Wii Console
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
    Connecting directly to a modem:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
Sep 13, 2010 | Nintendo Wii Console
My wii just turned off! I was watching a movie n my TV and everything just sut off my TV came back on but my Wii is still off!!
Was there some sort of power surge? A lot of the time when the power shuts off and back on -- there was a power problem. When the power comes back on, it can send a higher voltage which can break certain components. The Wii AC Adapter is made to absorb the shock rather than the Wii taking the shock. Try plugging it out and back in. If that does not work, you'll need a new AC Adapter. You can find one for around $19, free shipping, at the following page:
http://store.richspsxparts.com/ofniwiiacadr.html
Aug 12, 2010 | Nintendo Wii Console
My nintendo wii will not turn on
Unplug all of the cables from the Wii and the wall and TV and let it "rest" for 10 minutes. This is like a reset for the cables and, once you do this, it should work fine.
Dec 09, 2009 | Nintendo Wii Console
Wii won't power on
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
2022
Dec 31, 2008 | Nintendo Wii Console
How to Reset wii parental controls everytime any time
my nintendo wii after loading quantum of solace 007, it automatic updating. after that it makes my nintendo wii setting not work, it still asking for internet connection. Please send me email to rama.anggara@gmail.com if you have any suggestion. thanks so much!!
Oct 29, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
51 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
