To change the language on your HTC P3600, this is what to do.
Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings."
Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit."
Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you chose.
If you are referring to the display language, you may use printer's operator panel to change the display language
1 From a Ready status message, press Menu. The menu names appear.
2 Continue to press and release Menu until you see the Set up menu.
3 Press Select to select the Display language on the second line
4 Continue to press and release it until you see the correct language and press select to select the correct language
You may also do restoring factory default settings.
For further assistance, please contact Lexmark Technical Support.
