Question about Electrical Supplies
3000ise wont start by key. New battery - Electrical Supplies
  • 10,865 Answers
Is the battery charged? If not charge the battery and try it again. Generally most gasoline engines will start and run when these conditions are met:
1. good spark. If the spark plug is old, buy a replacement being sure to get the right plug. Then make sure the spark plug is gapped properly.
2. New fuel. If the fuel has been in the tank for more than two months replace it with new gasoline.
3. Air supply. Take a look at the air cleaner. If it is dirty clean it or replace it.
Food luck.
Posted on Jan 26, 2009
My uno mia 1100 wont start i buy new destipitor petrolpump en new ignison but stil not start
New ignition switch? New key as well. Immobilizer/Alarm needs pairing. Put key in ignition, disconnect battery for 3 hours. Connect battery, wait 15 minutes.
Aug 09, 2017 | Cars & Trucks
I have a Yamaha 3000ise inverter generator. It wont rev up to working rpm it just idles. If I throttle it by hand it produces the power as it should, any idea what the problem could be? Thanks
check for governor control lever, module, spring broken etc, any thing that is connected to the carby butterfly that is loose or not working as it should
Jul 09, 2016 | Yamaha Motorcycles
2009 jeep commandeer wont start, when I turn the key there is no sound, lights wont turn on and is that wasn't enough the key gets stuck in the ignition. any ideas?
it wont crank, no A/t car starts unless cranked first. (a key point)
fix head lights first. this is a feature in all cars.
that is SIMPLE and HOT all the time
they must work at all times and is the top way to diagnose
electric problems
you have a dead battery,.
only why remains.
i bet it cranks jumper cable started, call AAA or buy some cables.
or swap in a charged battery , or heck charge yours, buy a charger.
check fuses.
check battery lugs for green death?
check battery voltage. at 12.6vdc, if not charge the battery
if the battery continues to disgharge.
that is called phantom drains, or bad battery .
or the alternators is bad.(system)
once started the battery volts must be 13.3.to 15v, if not the charge system is bad ,(fuses, belts slipping and lots more possibles)
Sep 19, 2014 | 2009 Jeep Commander
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
Honda green key light wont come on and engine wont start
you may need to have your immobilizer reset at the honda dealership.
Nov 13, 2013 | Honda Cars & Trucks
My car wont start i installed new batterry but it wont start when i clicking ignition key
Does the new battery turn the motor over? Sounds like bad/dirty cable connections...
Jan 28, 2013 | 2008 Pontiac G5
New battery and car still wont start
did the security system kick in is the light flashing with the key on it?try another key may need to be reprogrammed
Aug 14, 2012 | 2008 Land Rover LR2
I have a 91 fzr 600 recently did oil change, spark plugs,didnt ride bike for 2 days then went to ride it today and wont start, thought it was the battery so i jumped it and it started but started running...
you will need to try a new battery, unfortunatly sometimes jumping of a larger battery can spike the regulator, so when the new battery is fitted put a mulimeter across the battery, should read just over 12v engine stopped and rise to 13.5-14v with the engine running.
Jun 10, 2010 | 1991 Yamaha FZR 600
I put a new battery in my 1990 maxima car wont start
try putting the key in the trunck and poping it it should reset the security
Jun 09, 2009 | 1990 Nissan Maxima
Electrical Supplies Logo
130 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
