Question about Dell Inspiron 2200 Notebook
I am trying to connect to the wireless in my new apartment. I have entered my network and password and that has worked fine. However, under Wireless Network Connection Status (i can get there by clicking on the little computer in the task bar) Under the General Tab it says: Status: Acquiring Network Address. And under the Support Tab it says Address: Invalid IP Address. I have already gone to Properties>Internet Protocol (TCP/IP) and fiddled around with that. Right now it's on 'automatic IP address'. I've tried putting in the IP address listed on my roommates computer. But that didn't work either.
    Novelist:
  • 176 Answers
On the Support tab - what does it say the "Address Type" ?
If its DHCP then check that on the TCP/IP properties;
If on "automatic IP address" then it wont take any entered IP address.
Do not put any IP address.
Check that "Obtain an IP address automatically" is checked and also "Obtain DNS server address automatically" is also checked. On wireless network tab check "Use Windows to configure my wireless network settings".
On preferred network check that your wireless network is there, if not add it and move it up
Posted on Jan 26, 2009
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
Trying to connect a new Dell E6500
You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Apr 22, 2010 | NetGear WGR614 Wireless Router
My dlink 524 wirrless G won't let me setup a password for security. I reset and go through the setup process. It seems to go fine until It asks me for my password that I thought was setup. It fails to...
Configuring the Wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field onpaper, and store it in a safe place. THIS IS YOUR WEP KEY, it will beneeded later on.
* Click “Save Settings”
Jan 22, 2010 | D-Link AirPlus DI-524 Wireless Router
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Got the router without instructions. How do I set it up to work with my lab top and desk top?
first thing you need to know is the default ip/password is 192.168.1.1 with the password being "admin" that will get you into the router im assuming your going wired to the desktop and wireless for the laptop, so first you'll need to hook the router up to the desktop using a cat5 wire from your network card to one of the numbered ports on the back of the router, ok now that you have a connection to the router open up a web browser and in the address bar type in 192.168.1.1, no user name and a password = admin, once your in there click under the wireless settings and enable the wireless network, change the ssid to something you like and can remember, then under the wireless security tab enable the wpa2 security encryption personal works fine then enter a nice password that you can remeber but isnt too easy to guesse, once you have that set up use the laptop to see if you can now see your new network and once you can try and connect to it using the password you just made up, now then if your going wireless all the way your still going to have to wire your desktop to the router for these initial steps once the changes are made then if you have a wireless card for your desktop then you can disconnect the wire and use your wireless card to find the new network and connect to it :) hope this is helpfull
Oct 13, 2009 | Linksys Wireless-G Broadband Router
Old xbox 360 & netgear are fine. but i cant get new xbox 360 to hook up to netgear. after i put the pass code in it still wont hook it up(online). it has full bars . its wireless. what should i do?
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
now scan for the wireless network on the XBOX and connect to the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 16, 2009 | NetGear WGR614 Wireless Router
Connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
Wireless stopped working on my msi laptop
No Wireless Connection Found in Range
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
Apr 06, 2009 | MSI MS-1022 Notebook
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
Jan 26, 2009 | Dell Inspiron 2200 Notebook
Wn121t won't connect to the router
Aug 18, 2008 | NetGear WN121T (WN121T100NAS) Wireless...
Dell Inspiron 2200 Notebook Logo
283 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
