Question about Garden
Carburetor diagram 2003 suzuki drz-125
Need the fuel lines placement (diagram)
rycgl
  • 1545 Answers
SOURCE: Do you have a diagram that shows where all the
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Oct 24, 2010
tellme2
  • 137 Answers
SOURCE: Wiring Diagram
hi there ,,havent tried these guys yet m8 ,but try the downloadable wiring diagrams ,,if they do them 4 your bike,, try this www.repairmanual.com this is a downloadable manual site,, cheers
Posted on Feb 27, 2009
voodoomox
  • 1689 Answers
SOURCE: 2003 Suzuki rm 125 repair manual
here you go buddy,
http://www.tradebit.com/filedetail.php/812559-2003-suzuki-rm125-motorcycle-service-manual
http://www.pro-bike.ro/forums/index.php?autocom=downloads&showfile=514
http://www.themotorbookstore.com/clymsuzrm19.html
regards,
voodoo
Posted on Jul 23, 2009
dontbother10
  • 2220 Answers
SOURCE: I NEED A DIAGRAM OF THE FUEL LINE TO THE
What you request doesn't exist. An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
e17de8d.gif Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
The serial number you provided allowed me to find the correct IPL for your saw Type 6 (-6 from serial number). Thank You.
If you feel Poulan should provide better illustrations please contact them here: http://www.poulanpro.com/node4033.aspx There is a toll free telephone at the bottom of the page.
If you contact them and aren't satisfied with their reply, please elevate your concern to their parent company (Husqvarna) here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
Posted on Oct 29, 2009
  • 3567 Answers
SOURCE: how do you change oil on a 2007 suzuki 125 drz
Just remove the fill plug to let air in then the drain plug to drain the oil. NEVER use synthetic oil or oils with "Special" additives. They can mess up your clutch. 10w40 motor oil is used in the gearbox. Pleas rate my answer. Thanks
Posted on Jan 10, 2010
My drz400E will start on choke, but will stop when turned off, then it won't start again..Please Please ant ideas
Hi, Bunty972 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Newbie Just bought 2006 Drz only runs on choke DR 400
DRZ won run off choke
https://drive.google.com/file/d/0B0fPe4feWkfeODBhNGRiZTEtY2RlZi00YWRhLTk0M2ItMThhYTlhNmUzOGEx/view?ddrp=1&hl=en&pli=1#
OEM parts for Suzuki
http://dr-z.pl/DRZ400SM%20-%20OM.pdf
Nov 24, 2016 | 2005 Suzuki DRZ 400 E
2005 drz 125L carb hose line diagram
Might be fuel leaking from overflow. Perhaps the float valve is stuck or damaged, allowing the float bowl to overfill. Slight chance tapping on side of carb may seat the valve. If not, it will probably have to either be set, or replaced. Could possibly have some "gunk" stuck in the valve seat from the cleaning. It only takes a tiny speck of debris to hold the valve open, causing flooding. Another possible cause is that during the cleaning, the tab that adjusts the level of the float valve got bumped, changing the level.
Apr 08, 2014 | 2005 Suzuki DR-Z 125
What are the valve specs for a 2003 suzuki drz 125
the intake is set at .004 and ex is .006
Sep 15, 2010 | 2003 Suzuki DR-Z 125 L
Why does my 2003 drz 125 have a ticking sound when i run it?
Also a four-stroke has the tendency to tick somewhat unlike the 2-stroke. If it seems too noisy or the ticking is more like a rattle have someone check your valves.
May 26, 2010 | 2003 Suzuki DR-Z 125 L
Need help with a suzuki drz 400e 2003 mod. After riding for the weekend decided to take spark plug out to change. Dirt fell down into head . I had a friend bike mechanic take head off to clean out dirt so...
Hi, Anonymous nice novella and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
DRZ400 Won Start
What to do When Your Motorcycle Won Start
Suzuki drz 400E Service Manual
Suzuki DRZ400SM Owner Manual
Mar 20, 2017 | 2003 Suzuki DR-Z 400 E
Carburetor
you need to dismantle it, cleaning kit needed and a air compressor / gas for washing. be familiarize everything when re-assembled.
Mar 26, 2010 | 2005 Suzuki DR-Z 125 L
2003 Suszuki DRZ difficult to start.
Make sure you are using the choke - which is actually not a choke, but a fuel enrichment circuit in the carburetor. The lever is located down on the carburetor. Also, you can try draining the fuel from the carburetor float bowl. Sometimes, just enough water will collect in there to make it difficult to start when cold.
Nov 14, 2009 | 2003 Suzuki DR-Z 400 S
Removing the carburator on a suzuki drz, 125.
It is quiet easy, you remove the seat then the fuel tank this will expose the carburetor then its simply a matter of disconecting fuel line and unscrewing attachement screws. why do you need to do this? I would be very careful doing this as any dirt or dust or grime getting in can have huge impact
Jun 06, 2009 | 2003 Suzuki GZ 125 Marauder
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
