Question about Krups 888 Centro
The coffee maker doesn't work - all the lights, timer, on/off switch, etc., seem to be working, but the water doesn't pour through the grounds to make the coffee
  • 56 Answers
Does it make steam or can you hear the water boiling? Try and pour 4 cups of vinegar or lime away in it if it is clogged or plugged up from lme or mineral deposits, if it not getting hot( you can tell very easily by seeing if the plate the pot sits on is getting hot) then the thermocouple or heating element is shot.
Posted on Jan 26, 2009
Coffee dripping out of spouts instead of pouring.
You have not included the make and model of the coffee maker.
Oct 15, 2014 | Coffee Makers & Espresso Machines
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
My friend gave me a Bunn thermal home coffee maker and I don't know how to make it work and can't seem to find directions on line?
Depending on which maker and how old it is it may have a switch for the heating element. The BUNN brewers have a reservoir inside that needs to be topped off BEFORE energizing the heating element/plugging it in. This usually will require about 3 pots being poured through until water starts to flow from the filter basket. (Have a pot in place to catch the water) Then it is safe to plug in your machine. After it heats up (about 20 minutes) you can load your grounds and pour through a pot of COLD water and voila... coffee.
Also, due to the reservoir you will want to not shut off or unplug your brewer... then it will be ready to brew next time.
Sep 20, 2010 | Bunn 10 Cup Home Coffee Brewer
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Oct 12, 2008 | Bunn NHB Coffee Maker
Water gets hot but doesnt pull water to grounds
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
May 13, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Water won't shut off
check the timer on the machine. it could be a mechanical or electronic timer. the timer's output goes to a water solenoid valve. could be the solenoid itself is faulty, but it all seems to point towards the timer - because you say it works fine normally. Is this a bunn coffee maker?
Sep 13, 2007 | Brewmatic 151 Coffee Maker
Krups 888 Centro Logo
1,414 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
