Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I have my fax machine hooked up through a magic jack. how do i change fax speed?
  • 15,935 Answers
I contacted the folks at MagicJack today and for faxes they confirm your findings. They suggest the following: We do not officially support using faxing with MagicJack. Please try the following steps to use MagicJack with your fax (contact your fax vendor for details):
- turn off error correction on your fax machine or program
- set the fax machine or program to use the slowest speed available
- increase the speed, checking at each speed that faxes work
The change must come through your fax machine, not the MJ.
HERE is a link to the manual for your fax machine.
If you are having problems sending or
receiving a fax due to possible interference
on the phone line, we recommend that you
adjust the Equalization for compatibility to
reduce the modem speed for fax operations.
a Press Menu, 2, 0, 2.
b Press a or b to choose Normal (or
Basic).
�� Basic reduces the modem speed to
9600 bps. Unless interference is a
recurring problem on your phone
line, you may prefer to use it only
when needed.
�� Normal sets the modem speed at
14400 bps. (Default)
Press OK.
c Press Stop/Exit.
Note
When you change the compatibility to
Basic, the ECM feature is only available
for color fax sending.
There are only 2 speed settings. Since the MJ does not support faxing, if the slower 9600 bps does not work, you will be unable to fax with the MJ.
Thanks for using FixYa - A FixYa rating is appreciated!!
Posted on Jan 26, 2009
Fax magicjack
  1. Operating Systems
    • As of 2010, the Magic Jack works well with Windows XP and Vista machines. Windows 7 has reported problems listed on their Microsoft Answers forum.
    Do Not Support
    • According to the Magic Jack company website they "...do not officially support using faxing with Magic Jack."
    Testing the Fax
    • Test your fax machine with Magic Jack by turning off the error correction on the machine and using the slowest speed available. If successful at that speed, increase the speed and check if it continues to work.
Read more: Does Magic Jack Support Faxing? ' eHow.com http://www.ehow.com/facts_7148239_magic-jack-support-faxing_.html#ixzz1tntAK093
May 02, 2012 | magicjack.com
Fax thru Internet help
Magic Jack is lying to you. ALL fax machines are Analog devices, Magic Jack is Digital
Jun 21, 2010 | Muratec M1250 Fax
Magic Jack
They are lying to you. It won't work reliably. All fax machines are Analog. magic Jack is Digital.
Apr 20, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
FAX MACHINE WILL NOT WORK WITH MAGIC JACK
Magic Jack will work with fax machines. You may have to experiment by slowing down the fax machines modem transmits speed. This is done in the machines menu.
The Magic Jack manual is quite clear, it can handle faxing.
Mar 21, 2010 | HP 640 Inkjet Fax Machine
My epson fax machine is hooked to magic jack and every time I try to send a fax, I get: communication error 0404
Can I fax using Magic Jack? This is a popular question. They do not support faxes, but the answer is yes. You may need to do some tweaking. However, not much tweaking. First, turn off error correction on your fax machine or program. Then, set the fax machine or program to use the slowest speed available. The slowest speed will ensure a fax goes through. You may increase later to find the highest speed at which a fax can be received.
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Machine not sending information.
Yes, most definately so. There are ways to boost the output signal of your machine but these days nobody has had to do it because lines are much clearer in the western hemisphere. The Magic Jack is great for voice calling but the faxes need instant responses from each other to progress through the initial training protocol and onto the document transmission. You may, if you have one, try another magic jack. It could be down to your particular Magic Jack. Try faxing without the Magic Jack.
Jul 08, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Problem faxing using magic jack
It won't help. Magic Jack is DIGITAL your fax machine is ANALOG
May 21, 2009 | Office Equipment & Supplies
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
355 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
