Question about Starbucks Electric Milk Frother
Starbucks milk frother stopped turning on - Starbucks Electric Milk Frother
Frother only blows steam not frothed milk
The frother is only supposed to blow steam! At least on any of the dozens of machine I have used commercially. You put the frother into your cup of milky coffee and it blow steam and air through the coffee and makes froth. Go to Starbucks, stand near the side counter and watch.
Edited to add yours in not a normal machine, it is a home replica of a pro machine. I suspect it needs cleaning. You can get milk cleaning tablets and liquid for machine that has an enzyme to remove dried or burnt on milk solids.
Here is your manual.
http://www.delonghi.com/Global/InstructionManuals/GB/GB-5713210861.pdf
Mar 07, 2017 | Coffee Makers & Espresso Machines
My Keurig Milk Frother stopped working. The green light comes on but turns off immediately. Is there something I can fix?
How long have you been using that? Why not try the frother from Kitchen Ace. I can assure you that the quality of there products are really awesome!
Amazon com Kitchen Ace Can Opener Stainless Steel with Smooth Edge...
Sep 12, 2014 | Coffee Makers & Espresso Machines
My nespresso milk frother red light doesn't come on, it is staying blue
I found that when I switched milks from whole to two percent organic it stopped frothing. When I tried a friend's creamer it worked again.
Oct 12, 2013 | Nespresso Aeroccino Automatic Milk Frother
Won't turn on.
The one-time thermal fuse is likely activated. Something caused it to activate. If it is out of Warantee, throw it away. It it is under Warantee, call the manufacturer. These are dispoasable and schematics and parts are not available. Repair will cost more than a new one.
Aug 19, 2013 | Starbucks Verismo Milk Frother
Why is my nespresso Citizmilk D120 milk frother not spinning? Milk does froth up.
I have the same problem. it was working beautifully but then stopped for no reason to turn. If I hold the whiskers sometimes they turn and other times not. Weird! it happened some months ago and then I tried a couple of months ago and it suddenly worked. Now the same problem has re-occured. Wonder which part needs to be replaced - does anyone know?
Mar 03, 2012 | Nespresso Citizmilk D120
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
The milk in the frother won't foam. I tried different kinds of milk but still doesn't work
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Sep 14, 2010 | Nespresso Citizmilk C120
Starbucks Electric Milk Frother Logo
557 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
