Question about Proscan PLCD3273A 32 in. LCD HDTV
I would like to know what the service port is used for on a PLCD3283A
Need a tv sensor for Proscan Model PLCD3283A
Sorry we do not sell part here, that said there are lots of online suppliers of parts for TV's and all electronics
Jun 26, 2017 | Proscan Televison & Video
My proscan plcd3283a won't turn on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. ...
Apr 08, 2017 | Proscan Televison & Video
This is the second Proscan that the volume breaks within 2 years of purchase. Is this a common occurance with proscan PLCD3283A?
Check the speakers first. If it found OK, check and replace the damaged components at its audio output stage circuit. If you wish to get more details visit the site linked here. This fault can occur to any brand TV at anytime. http://electronicshelponline.blogspot.com/
Mar 02, 2017 | Proscan Televison & Video
Replaced the main board for dead tv she works now but picture looks solarized thought i could go intp factory mode an swotch panel types but cant get into factory mode any ideas???
Check your lvds, connections or the flat cable that goes to your main and tcon that's connected to the panel as well. Take out and clean the cables connections
Feb 07, 2016 | Proscan LCD LED TV REMOTE CONTROL For...
My Printer is not printing although the printer status is online. How do I fix it?
If you tell it to print and the item goes into your Que for printing. In that screen click on the printer tab... In the drop down verify that the "Use Printer OffLine" does NOT have a check mark next to it.
Dec 30, 2013 | Zebra LP 2844 Thermal Printer
I cannot get my ps3 game to work. it says to consult my routers user manual to enable the setting in the games booklet. i cant because the manual has been lost. it requires a UDP port 9301. and i need to...
You'll need to setup port forwarding on your router.
From a computer use an internet browser such as Internet Explorer.
Assuming the router is using default settings.
1) In the address bar type in 192.168.1.1
2) You'll be asked for a username and password. Username is 'admin' and the password is 'password', no quotations.
3) Click on 'Port Forwarding / Port Triggering' on the left side bar.
4) Click on the Port Forwarding radio button.
5) Click the 'Add Custom Service' button.
6) For Service Name call it something meaningful, such as 'PS3.
7) For Service Type choose 'TCP/UDP'.
8) For starting port and ending port use '9301'.
9) For server IP use the IP address of the PS3, you can get this in the PS3 menu under Network Settings.
10) Click Apply
UPnP is supported by your router. On the left side bar, click 'UPnP'.
Feb 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I don't know how to port forward my comtrend adsl+
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "admin".
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Sep 25, 2009 | Linksys WRT55AG Router
Where is the low side ref connection on a 3500 serra 2005 truck?
dont know off hand but u can find it by following the larger ac lione/hose untill u find it remember large line/hose small service port,,,, small line,large service port is the high side ,u dont use high ide to gas up only the small service port large line
Jun 28, 2009 | 2005 GMC Sierra
Problem connecting with mates on fifa 09 on ps3.
here is the link for your port forwarding configuration:
http://kb.netgear.com/app/answers/detail/a_id/1166
here is the link for HOW IS PORT FORWARDING CONFIGURE:
http://kbserver.netgear.com/kb_web_files/n101145.asp
Instructions for RP614, MR814, WGR101, WGR614, WGT624, WGT634U, WGU624, WGM124, or WPN824 These routers do port forwarding by assigning port numbers to a "service" that is associated with the application you want to run.
To Let an Application Use Port Forwarding
  1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). The Setup Wizard appears.
  2. Enter the router's username and password.
  3. Under Advanced, click Port Forwarding on the left menu bar.
  4. A Port Forwarding Screen (Varies Slightly by Router)
  5. From the Service & Game (or Service Name) pull down, select the service that you will host. The services the router knows about are listed here. If the service does not appear in the drop down, add a service as described in the next section, then return to this step.
  6. Enter the IP address of your local server in the Server IP Address box.
  7. Click Add.
  8. Click Logout to exit from router settings.
To Add a Service for These Routers
To define a service not in the Service Name list, determine what port numbers are used by the service.
  1. Click Add Custom Service.
  2. Enter the first port number in an unused Start Port box.
  3. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box.
  4. Enter any name you choose for the service.
  5. Click Apply.
Apr 03, 2009 | NetGear WGR614 54Mbps Wireless Router...
Configure the firewall
You can use the Virtual Server to forward an individual port to one of your computers. You cannot forward the same port to multiple computers. In order to configure the Virtual Server you need to know the IP address of the computer that needs the port opened and the service port number. The links below will help you find the IP address of your machine. If you don?t know which port needs to be opened, try checking the software manufacture?s support website for information on use behind firewall. Configuring the Virtual Server: Step 1 Access the device configuration by entering 192.168.0.1 in your web browser. Login with your username and password. The default username is admin and the password is blank. Step 2a If the port you need to forward is a common port, it will be under the predefined virtual server list at the bottom of the page. Click the pad and paper icon next to the virtual server entry you want to use. The Protocol Type and Service Port fields are preconfigured. Click the Enable radio button to use the virtual server. Enter the private IP address of the computer that will use the service port. Configure the Schedule as needed, then Apply your settings. Step 2b If the port you need to forward is not listed under the predefined virtual server list at the bottom of the page, you can create a new entry for your application. Click the Enable radio button to use the virtual server. Give your virtual server a name. Next, enter the private IP address of the computer that will use the service port. Then, select the Protocol Type and enter the Service Port. If you don?t know how to use Private and Public port assignment, then just enter the same port number in both fields. Configure the Schedule as needed and Apply your settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Proscan PLCD3273A 32 in. LCD HDTV Logo
26 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
