Question about Saws
10" delta table saw overload relay button will not reset
stug_57u
  • 99 Answers
SOURCE: delta table saw
The reset button is normally a thermal overload, using a bio-metallic strip to break the circuit. If it is old or has popped a few times it might have 'weakened' abit. Try replacing the thermal/reset button. If it still happens then something might be overheating and causing the problem.
Posted on Nov 01, 2008
efs_perpends
  • 1996 Answers
SOURCE: I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
Posted on Mar 31, 2009
  • 384 Answers
SOURCE: How do I align the saw blade with the saw table
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Posted on Sep 15, 2009
buffalonyman
  • 1865 Answers
SOURCE: My Delta 10 inch table saw stopped working in mid-saw
you have to use a meter and check the voltage at the switch and to the motor.
Posted on Oct 09, 2009
VtToolMan
  • 704 Answers
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
TABLE IS PLUG MOTOR IS NOT RUNING
There may be an overload reset button on the motor (usually red). Check for a reset
Oct 23, 2012 | Delta 36L352 10" 3 HP 220V Single Phase...
My delta table will not start. I just used it yesterday. I don't understand. The power source is good. What is it?
Hi, check the motor for any external reset. Some have this, and others have the internal overload. If the motor is cool and its been off, it must have tripped the overload. Find the reset and your back in business!! Good Luck.
Shastalaker7
Mar 11, 2011 | Saws
The belt on my 10"
you need to check your brushes again. something is making contact or shorting out. look at everything carefully
Dec 25, 2010 | Delta 36 979 10 Inch Left Tilt 1 1/2...
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
Table saw cuts off
Probably the overload trip is set to too low a current. Either this or it is faulty.
It is just possible that there is dust in the contacts which causes a bad contact but it is more likely to be the overload trip.
Jun 02, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Delta table saw
Oct 12, 2008 | Saws
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
