Question about ASUS INTEL CORE 2 DUO T7200 2.0GHZ 13.3INCH WXGA 1280X800 COLOR SHINE INTEL 945GM 8XS (R1F-K049E) PC Notebook
I have color notes on my antroid phone & tablet, when i set up recurring task - routine - what ever you want to call it on the calender, and i ck this off when complete, it either cks all recurrin
Tasks appointments whatever you what to call them on calender and i complete this task it marks all future dates as completed or deletes future dates. CAN THIS BE RESOLVED?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
Try formating it by shutting it down... pressing vol up + power button and choose by clicking down or up vol... choose format/wife data factory... :)
Posted on Jan 19, 2013
The process.com.android phone has stopped
not 100% if this is a reload or not. Try powering it off if you can get past the popup long enough. If it can be reset- it may go away after it restarts, or need to be reloaded. There are plenty of guides for doing a recovery out there- but first just power it off and see if it clears before trying a recovery. There usually is a key combination to force a power off if you can't get past the popup.
Sep 07, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
Message keeps popping up....
Frequently, this happens do to a problem with your contacts or calender. It's a problem with syncing those items with your Google account or PC. If the problem is with one of these, you should try to manually synch the calender and contacts. (Go to Settings > Accounts & Sync > (Go to Gmail account). You'll see the option to sync the Calender, Contacts and Gmail. Select each one to manually attempt to sync the files. Determine which item is providing the error; you will need to clear the data from the problem application. (Note: back up your contacts first. Use the People > Menu > Import/Export > Export to SD card option if you can.)
Next un-check the sync option for the problem app (calender or contacts) under the Google Account > Accounts. Then go to Settings > Apps > Manage Apps > All and clear the data and cache for the problem app. (The contacts may be under the Running list.) Then re-enable the sync feature. If the calender is causing the error, you may need to erase and re-create your recurring item.
For some scrolling down to the Google Frameworks service in the Manage App > Downloads (or Running) menu then clearing that data. Then chose the "force stop" works to fix the problem. (However, this can put your cell phone into a factory reset state and may cause other problems.)
You will need to turn the cell phone off and back on before re-enabling the sync.
I hope this helps.
Jan 09, 2014 | Samsung Galaxy GT-S5570
Turn off alarm for calendar?
As far is I can tell there is not a global setting for turning off the alarm on the calender. Whenever you create a "Schedule" event on your calender the default seems to be for a "Reminder" alarm to go off "On Time"; that is to say the alarm will go off at the exact of your scheduled event. However, when you first create a "schedule" event you can scroll down to "Reminder" and choose from "On Time", "10 Minutes before", "30 Minutes before", "1 Hour before" or you can choose the one you would want which is "No Alarm". You can also find options on that screen for controlling what kind of alarm you want including the choice of having a "Vibrate only" alert to you scheduled event. You can always go back and "Edit" any events that are already scheduled and deselect the alarm for those events.
If you don't want to mess with the different alarms and alarm settings you might consider creating from the "Create Event" menu either a "Task" or a "Note" for a particular date on the calender. There are no default alarms associated with either of those. Create "Note is very easy to use. Just select a date and you can enter the time and other appointment information in the "Note" area of the "Create Note" screen.
I hope this is a helpful solution for someone.
Jan 13, 2012 | Pantech Ease P2020 AT&T
My phone software isn't smooth any more, I have been using this phone for 2 months, and after 1 month, may be because I installed a lot of apps, it started having this problem, that the scrolling isn't...
i had the same problem with my phone. The way i fixed it was to reset my phone i tried everything else but thats what i had to do.
save your numbers to your sim first and unmount your internal sd card in the settings before you do it that way you wont lose your numbers or pictures. Also if you have your calender set up with a google account you can sync your calender again after you reset your phone so you dont loose your calender. but make sure your calender is set up with your google account. Once you reset it you will loose all of your apps but your phone will run smoothly and then you just have to watch out for the apps you download.
Jan 18, 2011 | Samsung Galaxy S GTI9000 Smartphone
Recurring low pressure light and no clear issue
Note that the spare tire pressure is also monitored. If all of the ires (including the spare) are at the proper inflation pressure, and the light remains on, you may have a non-responsive tire pressure sensor; if so, that needs to be checked by a Toyota Dealer.
Oct 17, 2009 | 2007 Toyota Camry
E71 - make an event or meeting recurring in calendar - how?
Long press the calendar button.go to one below the bell icon saying not repeated. select and you get option of daily, weekly etc etc till you reach yearly. select the one you are looking for.
Sep 23, 2009 | Nokia E71 Smartphone
Sync Iphone with outlook
just install itunes and you can sync calendar and contact to your iphone. You cannot sync the notes and tasks but. I have just bought an iphone and before I was using an HP ipaq like you. Everything is synced except for the notes and tasks. You cannot even see any word or excel files you had on your ipaq. Cheers
Aug 21, 2008 | Apple iPhone Smartphone
ASUS INTEL CORE 2 DUO T7200 2.0GHZ 13.3INCH WXGA 1280X800 COLOR SHINE INTEL 945GM 8XS (R1F-K049E) PC Notebook Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
