Question about Husqvarna Sewing Machines
I have a Husqvarna Quilt Designer sewing machine. Should it be oiled?
    Scholar:
  • Husqvarna Expert
  • 104 Answers
Yes, but not excessively or all that often. To lubricate it where it needs it, the main bearings and other internal rotating and sliding parts requires removal of the rear and front covers. Leave that to a sewing machine repair person (doesn't have to be a Viking dealer - they often subcontract that kind of work to these guys anyway).
Posted on Jan 30, 2013
SOURCE: Husqvarna Viking Designer 1
Remove bobbin case,clean sencers with a soft brush.At 10 o"clock and 5 O'clock positions approx.
Posted on Jul 08, 2008
RickE1
  • 202 Answers
SOURCE: Husqvarna Viking Designer I (feed dogs will not lower)
Its likely this machines feedogs have either never been lowered or not lowered for a long time. Thus the old oil has hardend and is causing the mechanism to freeze up. A tech would take the bottom cover off, follow the connections from the lowering knob, button or switch to the feeddogs and putting a bit of oil or penetrant on each moving connection. Don't force anything, gently tap where you beleive its sticking and turn, push or flip the switch, knob or button slowly bit by bit, back and forth until they drop. They will work loose then make sure they get a bit of oil again. Hope this helps. Good luck.
Posted on Jul 15, 2008
kent581
  • 87 Answers
SOURCE: just made a floppy disk from quick font plus and now
1>Turn on machine
2>touch PROG (menu on top)
3>insert desired font disk
4>touch floppy icon
5>select font/font size
6>touch each letter consequtively until speeled (use "_" in menu for a space between words/names.
7>When done, touch REP (menu on top)
8> then start to sew by pressing start/stop
Posted on Mar 20, 2009
  • 192 Answers
SOURCE: I need the driver installation for my reader/writer d-card
Drivers are on the installation disk. 3D will have it on cd#1 and 4D on the dvd. With the disk in the drive, plug the dCard reader/writer in and use the "add new hardware" wizard to allow the drivers to install automatically. Now,either repeat this for each usb port or remember to always plug in to the same port.
Posted on Sep 06, 2009
  • 152 Answers
SOURCE: I have a Husqvarna Viking quilt 870 sewing
The overload message is usuall due to a bind in the mechanical function of the machine. When the motor has an extra "load" caused by something like a tight belt or dry bearing, it "overloads" the motor and the error message is displayed. It is doubtful your problem is computer related. Either way a trip to your service tech is required. If you continue to sew with it, you do run the risk of possible damage to some other parts of your machine. The computer portion of your Husqvarna is guaranteed for 5 years and the mechanical parts carry a 20 or 25 year guarantee depending on when you purchased your machine. A copy of your bill of sale from a Husqvarna Viking dealer or a stamped warranty card is the proof of purchase needed to obtain warranty replacement of parts. Labor is only guaranteed for 1 year.
Posted on Oct 06, 2009
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
Does the husqvarna viking quilt designer 11 sew straight stitches without using a card?
It is possible but it will only sew a straight stitch (more than likely a 2.5MM stitch length which is a common/standard length for straight stitching.
Jun 28, 2014 | Husqvarna Viking 1
My husqvarna designer 1 keypad doesnt work
It could be the Touch Screen. If it is a Designer 1. If it is a Designer II or Quilt Designer or #1 it could be the Dcard. Recommend it be checked by an Authorized Viking Dealer. You can find the nearest dealer from the Viking website - http://www.husqvarnaviking.com/us Click on the link Locate a Dealer.
May 21, 2014 | Husqvarna Sewing Machines
Husqvarna quilt designer II will not calibrate
Sounds like the touch screen has gone bad. You should take it to your nearest authorized husqvarnaviking dealer. You can find your nearest dealer at http://www.husqvarnaviking.com/us
May 11, 2014 | Husqvarna Sewing Machines
How to read the hours of operation Husqvarna designer 2
You need a service cassette (Service D-card) to do that on the Designer 2 and the Quilt Designer. It is expensive and only available to authorized service techs.
Mar 02, 2014 | Husqvarna Designer I
I can not remember how to lower the feed dogs on my Husqvarna quilt designer and I can not find my manual
I think the Quilt Des. is the same as the Designer 1 (which is what I have) and the lower feed dogs is a serrated dial (looks like part of a circle sticking out of the machine) located on the lower front of the free arm about 2 inches to the right of in line with the needle. You turn the dial towards the left to lower the feed dogs and to the right to raise them.
Oct 09, 2010 | Husqvarna Designer I
4D d-Card Reader/Writer Kit and Husqvarna Quilt Designer II
Assume you are loading your designs using Organizer? Yes? I have very limited experience of this, preferring to use Disk Manager (but you need to have this program which I am guessing you don't).
It is my understanding that Organizer will only load one design to an embroidery media, not a whole menu of various designs. However you obviously are not "seeing" even one design. Did a pre-loaded Husqvarna card come with your machine? I think it should have, but if it didn't then that doesn't help you very much either.
I am wondering if the D-card is not "formatted" for embroidery recognition. The Designer machines like to receive their designs in a certain file arrangement but I'm afraid I can't offer you advice on how to format the card - I do my formatting through Disk Manager.
However, while I was writing the above it did occur to me - are you loading designs that are the .shv format? Your machine will not recognize .hus, .vip, .vp3 or any other format. Please write back to this group and let me know if any of the above was useful to you. I belong to a Yahoo group that deals exclusively with Designer machines, so I will ask the group members if they can come up with any helpful advice.
Jul 01, 2010 | Husqvarna Designer I
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
