Question about Cell Phones
How can i get mixcaft 6 or 5 registrration code
    Master:
  • Cell Phones Master
  • 520 Answers
Hello Dear:::":"
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Jan 20, 2013
T-CP42S30. What is 6 blink code?
6 blinks means Driver SOS1 (SN Energy recovery circuit).
probably faulty SN-Board scan drive board. check the video too.
www.electro-medical.blogspot.com
Panasonic Plasma TV 6 Blink Code Explained Repair for 2011 Panasonic...
Aug 30, 2015 | Panasonic Televison & Video
How do i get sewing machine to stop showing code 6 when I have done everything by the book. sews perfect stitches for about an inch then code 6 and locks again?.
Since it is a computer,maybe try unplugging for about a minute and plug back in and turn the machine on. See if the code is cleared. hope this helps
Oct 02, 2014 | Brother Sewing Machines
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
Need 6 digit code for epixhd.com/activate ps3
There is only a Trial option for Epix. You can register here
http://www.epixhd.com/freetrial/
Otherwise , epix seems to be a pay2view service!
Apr 06, 2013 | Sony Playstation 3 (PS3) Console
What transmision does the Taurus have
that depend on a few things .like what do you have andF}}}400}1086932" CHECKED="" type="radio">A.T., (6-183, 3.0L), DOHC (VIN S), (AX4N), col shift
A.T., (6-183, 3.0L), DOHC (VIN S), (AX4N), floor shift
D}}}400}1086934" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AX4N (code X), col shift
E}}}400}1086935" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AX4N (code X), floor shift
C}}}400}1086936" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AXODE/AX4S (code T or L), col shift
A}}}400}1086937" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AXODE/AX4S (code T or L), floor shift
Jan 01, 2013 | 2000 Ford Taurus
Ford 2003 escape codes readed
Cauases or fault codes are not cut and dry, but here are the possible causes of codes P0316 and P0306 which are related codes.
P0316 - Engine Misfire Detected on Startup
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Engine fails to start
- Engine runs rough Possible causes - Crankshaft Position (CKP) sensor harness is open or shorted
- Crankshaft Position (CKP) sensor circuit poor electrical connection
- Faulty Crankshaft Position (CKP)
- Ignition System
- Fuel Injectors
- Running out of fuel
- Fuel Quality
- Faulty Engine Control Module (ECM) P0306 - Cylinder 6 Misfire Detected Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Lack/loss of power
- Hard start
- Engine hesitation
Possible causes - Faulty spark plug 6
- Faulty ignition coil 6
- Ignition coil 6 harness is open or shorted
- Ignition coil 6 poor electrical connection
- Clogged or faulty fuel injector 6
- Injector 6 harness is open or shorted
- Injector 6 poor electrical connection
- Improper spark plug 6
- Insufficient cylinder 6 compression
- Incorrect fuel pressure
- Intake air leak
Jan 17, 2012 | Cars & Trucks
The speaker volume is too low...please can you let me know...as to what the correct settings should be to obtain the loudest sound out of the speaker...as it is too small
Reset your mobile factory setting .
Go>setting >security>factory setting>
First Try it:
Defalt phones codes(NOKIA) is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 4 Digit Security code(LG) 0000
Default 5 Digit user code(SAMSUNG): 00000
Default 6 code for (MOTOROLA)000000 or 888888)
Default 6 Digit Security code: 123456 or 000000 or 888888
Default 6 Digit Security code: 000999 or 1122
Default 6 Digit Security code(SONY ERICKSON) no number
Good by
Jan 06, 2011 | Cell Phones
Area code of new zealand
To call NEW ZEALAND, you will need to dial: Exit Country Code + 64 + City Code + the number Here is the lists of City Codes: Auckland: 9 Bay of Plenty: 7 Christchurch: 3 Dunedin: 3 Hamilton: 7 Hastings: 6 Invercargill: 3 Manawatu: 6 Napier: 6 Nelson: 3 New Plymouth: 6 Palmerston North: 6 Queenstown: 3 Rotorua: 7 Tauranga: 6 The South Island: 3 Timaru: 3 Wairarapa: 6 Wanganui: 6 Wellington: 4 Whangarei: 9
Dec 05, 2010 | Lands Phones
Code for unlocking dvd regions samsung r155
hi,
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
Thank u
Oct 07, 2009 | Samsung DVD-R155
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
