Question about Refrigerators
Ge 19.7 ft. no frost refrigerator-freezer TFX20JR, TFT20JR leakes water
The water or the ice is constantly melting through the door is the Ice box has plain water frozen.
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    SOURCE: GE Monogram refrigerator/freezer problem/ice dam in ice maker
    I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
    Posted on Oct 22, 2009
    My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
    Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
    Mar 15, 2015 | GE Refrigerators
    Ge bottom freezer not freezing
    Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
    Leaking door gaskets can also be responsible for higher internal temps
    May 17, 2014 | GE GFSF6KKYWW 25.9 cu. ft. French-Door...
    On our GE refrigerator, water leaks out of the bottom of the frame for the water/ice dispenser and down the front of the freezer side door. What could be causing this?
    Did you just recently change your water filter? you need to flush 3 gallons of water out of it when changing the filter. if there is air in the line it'll drip constantly. If your ice door isnt closing all the way and properly sealing that also could be a source of water dripping. do you have a low of "Snowy" frost inside your freezer door at the ice dispenser shute?
    Aug 05, 2013 | Refrigerators
    My GE side by side refrigerator model PSC25SGSC has a problem. It makes ice fine. But sometime, all the ice cubes melted, along with the food on the top shelf. After I turned the ice maker on and off, it...
    Ok this sounds like your mainboard is about to go out, its causing intermittment cooling issues, board runs about $150-200.As long as you dont have any frost buidup in the back of the freezer, if not definitely the board. If you need any further assistance let me know.
    Sean
    Mar 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
    Hi freezer on american style fridge freezer is
    there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
    Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Whirlpool ultraease refrigerator (ED7FHG) making water sounds, and drips water onto steel pan in bottom rear of freezer side. Purchased new. This is an obvious change. Problem?
    You have a water leak somewhere (I'm assuming this water sound is constant). If not write me back for other possible solutions.
    The only place water comes into the freezer is for an ice maker or a door water dispenser. Check around the ice maker for a leak. If there is a water dispenser in the door then check the piping to it also.
    There is a drain in the bottom of the freezer compartment which is there so when the frost is melted by the defrost heaters, it has somewhere to go. This drain drains into the "drip pan" (or condensate pan) in the bottom of the unit. Here the water will sit until it is evaporated into the air.
    If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
    Oct 13, 2009 | Whirlpool 21.7 cu. ft. Top Freezer...
    I have a water leak that goes into control box & then leaks out forming a small icycle It is an IM-6 Ice Maker
    http://sites.google.com/site/sublimeappliancerepair/refrigerator-problem/defrost-info/ice-maker-quit-making-ice-im-secrets
    Here is a link to common ice maker problems. Chances are you have a pin hole in the water line. It may also be a leaky water valve which is on that link. also check for a broken ice mold. Best of luck.
    Sep 23, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
    We have a GE refrigerator that is leaking
    Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
    Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
    Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
    Sep 07, 2009 | GE GSS25JEMWW Side by Side
    Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Refrigerators Logo
    95 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
