Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
When powered on its show a blue screen with white lines on it !!
I have a Sony, KP-46WT500 rear projection TV (no remote) and when I tried to power it up only a blue video screen comes up with white lines and I can't get any station. What do I need to get it up and running?
  • xavier311 Feb 18, 2009
    i dont have that problem with the tv turning off !! it is just about the blue screen !!
  • Anonymous Feb 19, 2009
    having the same problem!
  • Sony Master
  • 5,138 Answers
If TV shuts off after turn on Blue Tube could be bad.
Posted on Feb 16, 2009
  • ladywinn
    ladywinn Feb 18, 2009
    ok what input do you have it switch to on menu?
  • ladywinn
    ladywinn Feb 19, 2009
    There is a self diagnosis mode for sony Its called sony blinking codes try this press display/ch5,/vol down- then press power.
BLUE SCREEN My sony KP 46wt500 hdtv ready rear projection has
Ur tv have a problem known as convergence problems.Ur tv convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
Jun 06, 2010 | Sony KP-46WT500 46" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Screen turns green and tv powers off.
visit your local service center. you cant do anything more up to this point
Jul 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Blue lines across screen sony tv
blown fues on the G board, that should fix my problem
and or might need to replace stk392 convergance amp ic's
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Sony KP-46WT500 46" Rear Projection...
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
