Question about Sony Ps-lx30 Stereo Turntable System Service Repair Manual
I own a sony ps-lx430 turntable. The tone arm sync function is not working properly, how do I fix this?
When i hit "play" the arm does not move to the record, and the turntable stops playing. *If i move the needle to the center of the record, it syncs to the beginng 7" point on the platter instead of the beginning 12" point. *after it has synced to the 7" point, i again move the needle back to the center of the record, *it then stops playing and returns to the tone arm cradle. *at that point, the tone arm syncs as it should normally. *i have to do this each time i turn the player on. is there a way to fix this problem?
SOURCE: Sony PS-LX500 Linear tracking turntable
I think it's kind of cheap to ask someone to pay $10 for an answer to one question. Sheesh!
I haven't gotten the answer yet, but a local stereo store pointed me in the right direction. Thanks anyway.
Regards,
Tom
Posted on Sep 22, 2008
  • 32 Answers
SOURCE: Tone arm moves to the middle rather than the beginning
There is 33and 45. that's the size of the record.There should be a level to change from one to the other.
Posted on Aug 08, 2009
SOURCE: won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Posted on Aug 23, 2009
SOURCE: My Sony PS-LX520 turntable skips with tone arm not moving
Yep - Just did the repair and it was as stated above. Had exactly the same problem you have and changing this tiny drive belt was the fix. I add more details and another source to find this belt:
I had the same problem and a review of forums and my experience with my own fix indicated that this is almost certainly your problem:
The roughly 2.6 inch (circumerence) drive belt (that connects a tiny motor to the worm screw that moves the tone-arm laterally when it gets the signal) likely needs replacement. Mine was intact but old and rigid enough to keep slipping or hang up the tiny motor. Unplug the unit - take out the 8-10 screws to take off the bottom - remove this little belt - scrub the pulleys with tripled-up sewing thread, and replace with new belt. This is a good source:
http://www.turntableneedles.com/Square-Belt-Small-26-Inch_p_227.html
$6.50 (paypal available) for 2 belts to reach their minimum, free shipping, arrived in 2 days.
You might also want to clean and lightly grease the rail that the tone arm rides on, but this is unlikely to fix the problem without a replacement belt.
Posted on Jan 08, 2011
Grubhead
  • 5151 Answers
SOURCE: I have a sony PS-LX33
First check that you can move the arm right across the turntable platter. Do this without a record to avoid scratching it. If you can take it to the middle at the same height as a record then no mechanical fault is present.
That being OK it perhaps means that too much weight is being applied to the stylus. You can adjust it with the weight at the end of the arm. It should have numbers on, try it on 1 or 2 to start with - playing a record. The idea being to get the pressure just right without making it jump out of the groove or too heavy giving a rumble sound. It's a question of trial and error.
Posted on Sep 15, 2011
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Sony PS-LX55II Tonearm Doesn't move when playing
Is there an antiskate or skew adjustment and also a way to set that counter weight? If any of those are wong then it wont work
May 11, 2013 | Sony PS-LX250H Turntable
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
Check the needle, if its not that then you can check the tracking, the relationship between downward weight on the needle and lateral movement across the record. you will need the manual for the instructions
It can be tricky so if you are not sure then consult a good hifi shop or tech.
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Sony PS-LX250H Turntable
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
Aug 07, 2009 | Sony PS-LX250H Turntable
Regards,
Tom
Sep 19, 2008 | Sony PS-LX250H Turntable
Won't start
- Put the mat back.
Jun 04, 2008 | Sony PS-LX250 Turntable
Sony Ps-lx30 Stereo Turntable System Service Repair Manual Logo
98 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
