Question about GE EGR3000 Gas Kitchen Range
Oven will not light. Ignition element will not even turn on
I have a magic chef gas range and the top of the stove burners work , the broiler works but not the oven..I think it is the glo bar. How the heck do I change this? It is a magic chef proven cooking performance from model # 8114p627-60 from about 1999
Posted on Jan 16, 2009
Magic Shef digital oven will not light. Model No. 8112P067-60. Bought in 1992. I have been told the digital part is discontinued. Please advise.
Posted on Sep 15, 2007
    Novelist:
  • 159 Answers
Most likley the oven ignitor is bad. There are two types one is a flat bar ignitor and the other type is round. I belive most GE units use the round type. The ignitor is a part that will go because it is on any time the oven calls for heat. I would make sure that you have 120v at the connector to the ignitor that way you know it is bad.
Posted on Jul 16, 2007
Ge oven will not turn off after replacing element
If the element stays on even when the control is shut off it is most likely that the contacts are welded together in the control. This usually happens when the element blows out with a big bang. If this is the case the control will need replacing.
Feb 16, 2014 | Ovens
All other burners work properly - even the broiler, but the oven will not light. There is no pilots - the ignition elements are electrical.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 31, 2010 | Hotpoint Ovens
Turned on oven, waiting for it to heat up and saw a bright flash of light and now nothing works control panel doesn't even light up
the bake element shorted out turn of the power to the unit and replace the bake element or bottom cooking element that will fix it
Apr 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
Oven light
This is done to regulate the temperature. Higher heat settings will let the element stay on longer, while lower settings will turn it off sooner. Even on high, the elements may turn off periodically because there is a switch called a temperature limiter. Its job is to keep the element from overheating.
Aug 11, 2008 | Dacor MCS130 Millennia Electric Single...
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
GE EGR3000 Gas Kitchen Range Logo
574 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
