I HAVE INSTALLED AUTOCAD 2010 AND REPLACED ADLMINT.DLL FILE THEN WHEN I RUN IN MY 32 BIT XP O.S .THEN THE ERROR COMES.
SOURCE: autocad 2005 incompatibility with new PC
Follow the link below to download the drivers for xp:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334440&linkID=9240618#section4
SOURCE: unable to initialize adlm at windows vista
use Autocad in windows 7 is great. vista is **** and doesnot support most of problems. i use autocad 2010 in windows 7 with no problem.......
SOURCE: is there any chance to
Maybe. Typically 32 bit programs will not run under 64 bit processors, but some will run under compatability mode. Navigate to the program and right click on it and specify run in compatability mode. Some older programs will not run under 64 bit, period.
SOURCE: how to fix acdb16.dll and acdb16enures.dll for
How to fix acdb16.dll and acdb16enures.dll for autocad 2010
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm (Windows XP)orC:\ProgramData\Autodesk\ADLM (Windows Vista) (Please note the file name may be slightly different for localized product versions, for example for the German version the file name is ACD2010-DEUAdlm.log)
If the log file shows errors regarding the product information table file, for example "Unable to locate the Product Information Table File" or "Product Information Table file is not found", you will need to:
- Uninstall all installed 2010 products
- Delete the ADLM folder mentioned above, and
- Reinstall the products
