Question about Sewing Machines
Janome 1 Step - model 2319S. How to replace Floating bobbin holder etc. also do you have a maual for this model?
Yes, fixed the problem this time - how, just fumbled around until it stayed put.
I find that I need Visual aids as well as the written word.
Since this was a 'cheapie' Model the 1 step, I guess there's no specific manual for it.
Many thanks for your time and effort - I know who to go to if I have other problems, thanks again.
Beryl Ross
Posted on Jan 27, 2009
Have a janome 2319s can I quilt and what tension do I need Barbara
You can quilt with pretty much any sewing machine. But, are you asking about piecing quilts or free motion quilting? You should be able to do both but they are very different projects and require a lot of different settings and accessories. Tension is correct when the top and bobbin threads meet in the middle of the fabric being sewn. Tightening or loosening the top tension should help achieve that.
Jan 22, 2018 | Janome Sewing Machines
My sewing machine is a Janome Magnolia 7330. The hand wheel will not manually turn backwards to raise or lower the needle. When sewing, the bobbin stitches are loose and looped.
I would find a local sewing machine sales and repair shop near you. You will need to have them look into this, it may be a timing issue or a broken or damaged part.
Feb 16, 2017 | Janome Sewing Machines
I am looking for a manual for a janome 1 step model 2319s can you help me please
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 13, 2015 | Janome Sewing Machines
Problem with thread getting caught under bobbin holder
have you applied any lubricant to the bobbin holder the one that holds the bobbin? I would suggest using your manual and lube your machine. sounds to me like your mechanism is sticking.
Jun 08, 2015 | Janome Sewist 625e
Janome 6500 Memory Craft Prosfessional is my machine. I had it serviced in auckland last year through the Thames Janome shop as the Thames repairer could not fix it. Needed a new shuttle anyway. Anyway my...
You need to ask Janome these questions, rather than Fixya I think. The plastic bobbin in the plastic bobbin holder does make a little bit of noise but I don't find it problematic.
Janome New Zealand Limited reader.gif Unit 5, 325 Ti Rakau Drive, East Tamaki, Auckland, New Zealand
TEL. +64-9-265-0250
FAX. +64-9-265-0251 black.gif E-mail
Web-site black.gif shannon@janome.co.nz
www.janome.co.nz
Providing you are using "Janome" plastic bobbins and are putting them in rotating the right way, as per the little image on the clear cover, there is no reason that the thread cutter should be dislodging the bobbin. When I use the thread cutter, my bobbin turns as thread is drawn off it, but it doesn't move upwards.
Sounds like you have already replaced the black plastic bobbin holder, is that what you mean by "Shuttle"??
My 6500 has had 2 replacement bobbin holders as I keep striking it with the needle during jam ups, which caused plastic burrs on it. On the last service the technician added a little piece that is a janome "after sale replacement" part. It is slightly longer than the standard part, and is a little metal bit on the left hand side of the rotary hook area which seems to be working at holding the bobbin holder in place better. Haven't had a big jam up since he fitted it. But before this, I would dislodge the bobbin holder with a small jam, and then it would just jam and jam until I removed the needle plate with the screwdriver, removed the bobbin and bobbin holder, cleaned out all the thread fragments, then replaced the bobbin holder back into the correct position lining up the two red arrows. Then replaced the needle plate and rethreaded. I learnt to modify my sewing expectations and not try to sew really thick seams as this will just dislodge the bobbin holder again. Jeans hems were always my problem seam, I use a "Seam Jumper" now to handle going from thin to thick seam, and so far, so good.
So I would suggest you ring Janome in Akld and talk to their technical advisor a bit, describing your problem. They may suggest sending it to them for a check out to establish what is going wrong.
If you have trouble describing the issue to then you could always film it with a digital camera and send the file to them.
My only other thought is how you wind the bobbins. It is really important to wind the bobbin smoothly and evenly top and bottom, my 6500 will wind all in the middle if I let it just run, so I always wind carefully and give the thread a nudge with my fingertip to ensure it fills evening top, middle and bottom. But it sounds like you are an experienced sewer and know this already.
I'd say ring Janome and have a chat, I find if you keep your approach friendly and neutral rather than "I've never got on with this machine" that you may get some help from them at resolving this issue.
Jun 27, 2011 | Janome Memorycraft 6500P Computerized...
The bobbin seems to be stuck and will not move...all it's doing is 'eating' the thread...what do i do? Thanks
Can you get the bobbin out of the bobbin holder? unplug the machine, then remove the needle plate, needle and pressure foot. Now can you get the bobbin out? It is possible that the bobbin holder has moved in the rotary hook, they can jump sometimes as held in by a magnet.
Check out your manual for instructions to remove the bobbin holder, it should show you how to take it out, and then clean under it, there is possibly thread caught in this area causing the malfunction.
You may find turning the fly wheel a little to turn the hook will help to free up the holder and get it out.
Here is image from my Janome 6500 manual, it should be similar for your MC.
So clean out the underneat of the bobbin holder, then reinsert it, and reassemble, thread and test. If this doens't sort the problem, then time to drive it to the Janome shop.
May 23, 2011 | Janome Memory Craft 9000 Computerized...
My Janome one step is jamming on the first stich under the foot. I think it is the bobbin holder that has moved as it now comes out easily but do not know how to put it back in so it is secure
Raise the needle to it's highest position and this will position the shuttle so it is the correct position for the bobbin case to be inserted.
If this is a drop-in bobbin, the line-up is easy to see. Refer to the maintenance section of your manual.
If this is a rotary bobbin, make sure to hold the lever on the back of the bobbin case out as you insert it into the shuttle. The "arm" on the bobbin case points up.
May 01, 2010 | Janome Sew Precise Mechanical Sewing...
Singer cg-590 floating bobbin keeps jumping out of it's holder.
I'm not completely familiar with the model, but even a floating bobbin holder as you described should have some sort of a hold down. There may see a small swinging arm on the bottom right side of the bobbin area that needs to be located over the bobbin case to hold it in place. Let me know if this doesn't work.
Feb 20, 2009 | Brother CS-8072 Computerized Sewing...
Sewing Machines Logo
355 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
