Question about Gaggenau Ovens
Turn off child lock hleb27
Am staying in someone's house have put on child lock by mistake oven won't work help!
SOURCE: Neff oven B1641 child lock
I actually had the same problem and got the solution. Maybe its a bit late, but hopefully there will be somebody who find this useful as well.
Its not an error. The -5- indicates that the oven is "children protected".
- Put the left ON/OFF switch into its OFF position (the left switch)
- Turn it quickly 3 times: one click to the left and then one click back to right again [light position, Off position]
=> The message disappers.
If you do this again, the protection is switched on again.
Greetings from Germany
Posted on Nov 22, 2008
SOURCE: how do I switch off child lock from my neff oven 1641
So, you should have a "-s-" being displayed if you have the child lock on.
The switch for selecting the oven mode( oven, fan oven, grill etc)
-from its off position, turn it one click left so the light comes on, and then click it back to off. Do this three times in quick succession. The "-s-" should now have disappeared and you can use your oven again.
Regards,
Steve.
Posted on Dec 18, 2008
pctech1
  • 1940 Answers
SOURCE: The lock symbol is appearing
To deactivate the system lock:
  1. Press the "On" control to activate the display.
  2. Call up the SETTINGS menu.
  3. Call up the SYSTEM LOCK submenu.
  4. Select the touch control next to "Do not accept" and confirm by touching "OK".
  5. Press the "Off" control.
To activate the system lock:
  4. Select the touch control next to "Accept" and confirm by touching "OK".
Using the system lock:
  • Select the touch control next to the Unlock symbol and confirm "on". The oven cannot be operated now. The Lock symbol indicates that the lock has been activated. The timer can still be used while the lock is on. The system lock remains active even after a power cut.
  • To switch the system lock off call up the Lock symbol and confirm "off". The oven can now be used.
- Note: If the system lock is activated for more than 4 days, the oven clock will have to be reset.
Posted on Apr 24, 2011
  • 17 Answers
SOURCE: says oven door is locked...it is not. none of the
I had the same problem with my oven.Mine is a different make and model but try by opening your ovenand move your locking lever for cleaning look at the actuall hook that locks it and find where on the oven itlocks into sometimes there is a safety switch in that hole that gets stuck.Try by messing with the safety switch with a screwdriver or something to see if the door off light goes off.Good Luck.
Posted on Jul 17, 2011
nainamainaka
  • 380 Answers
SOURCE: ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Posted on Nov 22, 2011
    When I try to turn my oven on, it says LOC. I don't know how this happened or how to reset it. Stove was in the house when we bought it a few months ago.
    That message is normally visible when cleaning the oven at high temp. Or it is the child lock. Did the owners ask if you wanted to buy it and you said "No thanks" :>)
    Try removing the power plug at the back for 30 seconds and reconnect. If that doesn't work Google
    make model manual
    Removing the child lock often just involves holding two or three keys for a few seconds.
    Apr 22, 2016 | Ovens
    Turn off child lock
    Can you identify the model of the oven you need help with or anything like that? Not all child locks on ovens are configured to function or be utilized the same way.
    Sep 22, 2013 | Ovens
    Oven won't turn on because someone played with timer
    Try turning the mains supply off and it will probably reset everything.
    Feb 01, 2018 | Moffat Ovens
    Probe light on convection oven stays on. Clock won't display. Oven still works though.
    Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
    Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
    I took the door off my Simpson Evolution oven and now it won't go back on. Help
    you have to push the hinge down and lock it you will need a screwdriver and turn the round disc the one will the slot in this will hold the hinge down do this both sides of the door and put the door back resting into the oven and then turn the slotted discs and that should do the job
    Apr 21, 2012 | Smeg Evolution SCP171X Dual Oven
    Lock electric oven
    is this for child protection, you could put it into cleanning mode then turn the unit off it will stay locked till you turn your oven back on , could also trip the braker , Just a thought
    Dec 03, 2011 | Ovens
    How do I remove the child lock message on my Panasonic Inverter Microwave?
    Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
    Aug 20, 2011 | Ovens
    When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
    Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
    Jun 13, 2011 | New World Ovens
    Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
    Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
    May 05, 2011 | Electrolux EOB6632 Electric Single Oven
    How do I switch off child lock from my neff oven 1641
    Regards,
    Steve.
    Sep 09, 2008 | Neff B1641 Single circotherm super...
    Ovens Logo
    32 people viewed this question
    Top Gaggenau Ovens Experts
    Dennis Boxerman
    Jaime Hernandez
    ashburton
    Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
