it goes through all the cycles - and will pump water out if you poor water in it manually. It heats and goes through all the cycles. I just does not wash because no water comes in.
-   dishwasher continually running but appears no water is coming into the tub. also when the unit starts you hear a chattering sound like a solenoid also water is laying in the bottom of the unit under the motor and pump
-   sdvglenn
Mar 29, 2009
-   i have the same problem. wash ths the solution and how much did it set you back?-   Guest
Hi - I used the self-clean feature on my Viking oven 2 days ago and now it won't unlock and I can't...
(More)
Hi - I used the self-clean feature on my Viking oven 2 days ago and now it won't unlock and I can't any burners or the oven to work. Any advice would be appreciated.
water was shut off during dishwasher cycle not dish water will not work no water even though water...
(More)
water was shut off during dishwasher cycle not dish water will not work no water even though water is back on
Viking dw 20.3 does not complete cycle or open soap door. It does drain and fill ok . When it stops...
(More)
Viking dw 20.3 does not complete cycle or open soap door. It does drain and fill ok . When it stops both "pots and pans" and "heavy" are lit, but dishes are dirty. .Thanks, JimBringe@hotmail.com
viking dishwasher sounds like it's running but doesn't actually wash. It will empty water if I put...
(More)
viking dishwasher sounds like it's running but doesn't actually wash. It will empty water if I put some in.
