Question about Samsung SyncMaster 191 N (Silver) 19 in. Flat Panel LCD Monitor
The screen display then go off (sync master 191N)
How do I reset a 2008 ford fusion stereo?
Hello Chad... As I'm not sure which SYNC Version you have, go here for info on "How To Perform A Master Reset"
https://owner.ford.com/how-tos/sync-technology/sync/settings/how-to-perform-a-master-reset.html
Jun 30, 2016 | Ford Cars & Trucks
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Computer does not display full screen
Check your desktop display settings. Sometimes programs change this and uninstalling or going to to another start point doesn't help
May 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Cant get size from display settings for external 19" Samsung Sync Master 931B cant see start button everything to large
See if you can pull up the menu on your monitor. If you can reset it to factory defaults.
If you still can't see the screen properly then you need to on your computer. Go into the device manager and make sure its seeing your video card properly. Look underneath display adapters and be sure its seeing something other then standard display vga.
If not then your display adapters are missing so once you install those, the computer will recognize your monitor.
Dec 18, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Hi, I am having Samsung LCD sync master 943nwx, after power on momentarily display is coming and going,
it may simply be a lose connection with the monitor cord. or the monitor cord may to be replaced.
Jul 12, 2009 | Samsung 15.3" LCD Monitor
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung SyncMaster 191 N (Silver) 19 in. Flat Panel LCD Monitor Logo
24 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
