Works fine other than this one problem.
SOURCE: MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
SOURCE: Panasonic microwave nn-s548wav, No lights
This is likely a problem or loose connection on the control unit circuit board.
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Panasonic Microwave NN-S935BF turntable and light
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
No power to light or turntable
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
SOURCE: Panasonic microwave model NN-2959: can't open door.
Your DOOR LEVER probably is broken. To open the door remove the filter (2 screws at the top) then remore the control panel by removing the screw holding it in place UNPLUG THE MACHINE. then unlatch the door. BUT I am trying to find a door lever and find they are no longer availabel.
