Question about Singer 2662
Needle still moves when filling bobbin
Model 2662. all of a sudden the other day when filling bobbin the needle was still moving. I don't know how to get it to stop. the bobbin is placed on the spindle & then moved over to the lever which is suppose to be the position for the bobbin to thread , but the needle to stay still. now all of a sudden it has decided to keep moving. any hel would be appreciated.
  • snowlady80
    snowlady80 Jan 21, 2013
    got brave & took the cover off. the wheel that is suppose to meet the spinner wheel is not catching right. am looking for a repair man in my area. Thank You for your Help.
  • sylviaivie Jan 21, 2013
    Does it have a little rubber tire? If so, those do wear out just like they did on antique machines. Maybe all you have to do is replace that? At any rate good luck and happy sewing.
  • Singer Master
  • 1,564 Answers
Something is broken, or slipped out of place. take it in for repair. While you are at it have it cleaned, checked and retimed if needed.
Posted on Jan 19, 2013
5 Suggested Answers
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
Posted on Jul 31, 2011
dupina
  • 110 Answers
SOURCE: Model 7462. When trying
Your machine needs to go to dealer to rectify the problem. Your machine sensors are telling the machine that the needle bar is not idle while winding the bobbin and the flashing lights is a warning message. Nothing serious and your dealer should be able to fix it in 30 minutes. You need to remove the covers and hand wheel, so best to leave it to the experts
Posted on Aug 23, 2011
  • 980 Answers
SOURCE: just bought it and when i turn knob toward me
Change the needle first, if that does not work you may need to retime the machine, I can attah instructions if you want to do it yourself, kendourof@yahoo.com
Posted on Aug 25, 2011
How to fix a hand wheel that doesn't move.
if its stuck physically then don't force it , have a look with a strong light in the bobbin compartment for foreign objects , ive seen needles break off and lodge in the bobbin spool locking it tight
Mar 10, 2016 | Euro-Pro Sewing Machines
Singer 2662-when I press the foot control the motor revs but doesn't make the needle go up and down.
Most sewing machines have a switch to position for sewing or for spinning bobbins. Make sure it is in the sewing position and not for spinning bobbins. I have several sewing machines (not your model) and they all do that if they are set for spinning bobbins.
Feb 05, 2013 | Singer 2662
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
Needle is hard to move up and down
try changing the needle
clean under the needle plate & in the bobbin area for lint or threads
rethread the machine top & bobbin
make sure the bobbin isn't too full
make sure the bobbin is not damaged or warped & that it is the right
bobbin for the machine
make sure the bobbin is turned the right way in the bobbin case
if none of these suggestions help then the machine needs to be
checked at a repair shop
Aug 30, 2012 | Kenmore 15516 Mechanical Sewing Machine
Bobbin won't move
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
Singer 2662 Needle doesn't move
when was the last time the machine was serviced?
Apr 11, 2012 | Sewing Machines
Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
Mar 18, 2012 | White Sewing Sewing Machines
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Singer 2662 Logo
96 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
