Question about Dryers
Indesit tumble dryer running cold even though I've replaced the heater element..?
    Genius:
  • Dryers Master
  • 1,669 Answers
Check the control panel for a fuse or a bad thermostat control.
Posted on Jan 19, 2013
jsrock516
  • 5911 Answers
SOURCE: blowing cold air
There is not a reset button on an electric dryer that I know of. If a dryer is blowing air at all, that tells me that the blower assembly and drum motor are working. If you have not heat it is generally caused one of the following:
1. Bad thermal cut-out - located near the heating element housing. Should read a SHORT (0 ohms on an ohm meter) if good. If bad, it is generally a good idea to replace the TCO along with the Hi-Limit Thermostat (mounted right next the TCO in most cases) because the TCO is designed to protect the thermostat and heating element. If the TCO fails, it is likely that the thermostat could also be damaged.
2. Hi-Limit Thermostat failure - located near the heating element housing. The thermostat opens when the internal heat reaches about 157 degrees (on most dryers). This helps regulate the dryer temperature and helps protect the heating element. If it reads a constant OPEN (infinity reading on an ohm meter), replace it along with the TCO (as mentioned above).
3. Bad Heating Element - located under the drum on some dryer models and in the rear on others. The element should read about 9-11 ohms if good. If they go bad, the element will generally burns itself OPEN.
I will need you model number (located near the dryer door opening) in order to give you better advice on how to access the inside of the dryer. Post back with comments and let me know. I hope you find this helpful.
PS I hope I didn't insult your intelligence, but some people are little more saavy than others, so I try to explain things in the simplest of terms.
Posted on Jan 14, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
SOURCE: indesit condenser tumble dryer water
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Posted on Mar 13, 2009
apart4u
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
SOURCE: how can i fix my indesit is70c tumble dryer?
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Posted on Jul 28, 2010
White knight 427 not heating
Heating element is probably burned out. Or the thermal fuse / cutoff. I would check the fuse first as the heating element has 2 independent heating coils and usually both won't burn out at the same time. It would be best to have a meter tester. I am in Lake Worth, Fla. I travel within a 40 mile radius How to Replace White Knight Tumble Dryer Heating Element Heater...
Sep 12, 2014 | Dryers
Indesit tumble dryer only gets warm
is one of the elements broken on heater
Dec 01, 2012 | Indesit Dryers
Replace indesit IC70s element
Not sure which model you have but most heating elements are accessible through the back panel of your dryer. Take it off. locate the element, remove it and replace it. There should be about 3 screws holding it on with three wires going to it.
Oct 04, 2012 | Miele T7744C Dryer
Tumble Dryer intermittent squeal, then stopped heating, now black soot underneath
Dryers are susceptible to lint fires in their exhaust vents. You should be checking the exhaust vent at least once a year and clearing any blockages. If the exhaust vent becomes blocked, the dryer will heat up significantly and the lint could catch fire if there is enough heat build-up. If you don't clear the exhaust this will almost certainly happen.
Fire needs a source of heat (red hot heating elements), fuel (lint) and oxygen (the exhaust fan blows air at the blockage).
You should be able to replace the burned out heating element if you are comfortable doing the wiring. You can pay a repairman if you like but wiring is only so much common sense. Photograph the wiring before you start for a post repair check. Replace the element and any burned wires. Make sure the connections are tight and that there are no loose wires. Only the ground wire should be bare.
A Dryer uses 220V AC (in North America) like a stove and some water heaters. This is enough voltage to kill even hardy souls who laugh at 110V (usually enough to kill but not guaranteed to).
When you check the vent, check that it has some sort of safety rating. Not all flexible vent is fire-resistant. This scared me when I saw it on YouTube or somewhere.
Why did your smoke detector not go off when the element melted?Good thing to know if your utility charges less for power in off-peak hours. My mother often runs hers at night when the rate is very low.
My dryer runs from sunrise to sunset but we use an electric one in the winter months.
Sep 20, 2012 | Indesit IS70C Electric Dryer
Hi I have an Electra tumble dryer which dont heat up ! I've changed the heater element which hasn't cured it so I taped the full heat thermostat wires together but stil no heat ?? Thanx
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 18, 2011 | Electrolux Dryers
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Indesit Dryers
Tumble dryer running but only blowing cold air
If your dryer is turning then things are not so bad. If a dryer is not heating then you need to check a few things.
First disconnect the power to the unit. Then you must check the heating element and the limits which are mounted on the heating box.
Remove one lead from the element and check for continuity thru the element. If you have continuity then check the limit by measuring for continuity, again you must remove one of the leads. This should solve your problem
Sep 15, 2009 | Dryers
Tumble dryer not working
SOUNDS AS THOUGH YOUR HEATER ELEMENT HAS GONE..
IT IS POSSIBLE TO FIX IT YOURSELF BUT VERY COMPLICATED, CALL OUT FROM A REPAIR PERSON IM AFFRAID, COMBI WASHER/DRYERS ARE RENOWNED FOR THIS & ALSO BEARING KITS
May 22, 2009 | Indesit W 123 Front Load Washer
Common faults -
Feb 24, 2008 | Dryers
Dryers Logo
48 people viewed this question
Top Dryers Experts
