Question about Whirlpool Dryers
Whirlpool electriv dryer
Everything works on dryer except dryer does not dry clothes, no heat
  • 706 Answers
In all probability, you have either a blown thermal fuse ( non-resettable type) or an open heater element. Next post, please include the model so that I can provide more detailed information for you..
Regards,
Rick
Posted on Jan 26, 2009
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Dryer runs as usual but won't heat up.
you need to check continuity across the heating element with an ohm meter looks can be deceiving
Apr 14, 2009 | Dryers
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool gas dryer wont heat up
Hi!!! you seem to have a problem with the coil boosters..located above the gas valve..Its shown here .Good luckk..8035205.jpg
Jan 21, 2009 | Whirlpool LGR6636 Gas Dryer
My dryer is acting up
Sounds like you've done everything except check for air flow? When you run it, do you get ANY air flow thru the vent? If not , then your blower is either defective, not working or clogged.. Hope that helps..
Aug 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
