Question about Logitech C110 Webcam
My picture is to dark how can i fix that?
I need the settings to fix it.
  • Logitech Master
  • 27,725 Answers
A Logitech Quickcam can take still images and video. Make the most of your webcam experience by setting it to take the best pictures possible. Here's how.
Double-click on your Logitech Quickcam icon. This is generally one of your desktop icons. You can also click your Start menu option on the lower left of your screen and choose it from your list of programs. Click "Camera settings" on the right of the new window that comes up. You can also get to the camera settings by clicking "Quick capture" and then clicking the arrow on the far right. Choose which settings you want to work with first. You will have the option of Video and Audio. The video option controls the picture while the audio option controls the sound. Go back to your main window and click "Quick capture." This will activate your webcam and allow you to view what it will look like as you adjust the different settings. Move the bar back and forth on the Brightness, Contrast and Saturation. Do these one at a time while viewing the image on your webcam until you are satisfied with the quality of the picture. Click and un-click your Low Light Boost and Color Boost options to see which, if either, is needed to make your picture quality what you desire. You can turn these on and off based on the lighting of the room at the time. Click on your Audio option once you are satisfied with your picture quality. A check mark will appear if the volume is at a good level. If you choose to reset it, click the Configuration option. Follow the steps on the Configuration Wizard once you select the Configuration option. The wizard will walk you through testing the sound on your webcam to ensure quality during live webcam chats. Hope this helps.
Posted on Jan 19, 2013
Why are my pictures so dark?
Your ISO was to high or to low , I cant see your pictures to tell, but darkness means you diidnt let enough light in the lens set your appuatue to a small number and slow down your shutter speed. It will help preveiw your pictures before you print . Download Picasa for free and fix your pictures its easy. Goodluck Ozout!
Jul 28, 2014 | Nikon D5100 Digital Camera
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
Philips HD Projection TV just too dark (No Luminance)
sounds like the coolant needs to be replaced in the CRts as that will give you a very dark and dull colored picture. The phillips CRT coolant replacement kit at the following link contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 22, 2009 | Televison & Video
Color
If the tv looks now dark this is the first symptom of a lamp replacement (refer to the user's manual to do this job) and get a Mitsubishi original replacement.
the best picture setting (when the lamp is back of course) depends in the light of the room.
Now if after replacing de lamp and playing with the settings and the screen still pale, dimm, not enought color. a cleanning in the reflexion area is needed. (technican job)
Apr 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The picture in the LCD is too dark & the photos are too dark.
What settings are you using in the camera? Check the camera's metering mode selected. Set this to Multi Segment. If this is correct, check for any smears or dirt on the lens. Even fingerprints on the lens can cause these type of problems. Also if you are shooting in low light, use a higher ISO.
Feb 06, 2009 | Kodak EasyShare C743 Digital Camera
Samsung DLP Dark Picture
try to reset the tv setting to its manufacturer settings and see if it fix the problem
Feb 01, 2009 | Samsung DLP HL-P5663W 56" TV
Picture is dark when taking it at night.
Hello did you try brightening the frame rate of the camera?? and the quality of the picture?? That usualy would help..
Jan 14, 2009 | Canon PowerShot SD1100 IS Digital Camera
Cannon XTi
Try the camera in the full Auto mode to see if it is working correctly. Also check to see that there is no compensation set in the exposure settings for both apature and speed.
Check in the instruction manual to see how to get in to these settings from the user menus.
If this does not work, the camera will need to be serviced for a fault condition.
Jerry G.
May 28, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Picture problem
You need to replace the lamp to fix that issue. The lamps part number will be on the side of the TV. The part number will vary from set to set deending on which light engine it has in it. The part number will start with BP96-0???. It is a user replaceable part.
Jan 09, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Camera Flash & Picture
I just got this camera for Christmas the only way that I know of how to fix it is to change the exposure manually. If the picture is to bright you need a negative exposure, if it is to dark you need a positive exposure. I have noticed that the auto exposure does not get the correct setting that you need for the lighting.
Oct 11, 2007 | Polaroid A500 Digital Camera
Logitech C110 Webcam Logo
85 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
