Need instructions for performance router 1020w FMTC1020R
Reset button location
To perform a hard router reset, keep the router powered on. Then, find the unit's reset button, often located on the rear of the device. Use a pen tip or bent paperclip if necessary to depress the button and hold it down. Network administrators are taught to hold the button down for 30 seconds; your router probably does not require waiting that full length of time, but this is a good general rule to follow. After releasing the hard reset button, a router may need up to 1 minute to reboot and resume normal operation.
An alternative method for hard resets involves holding the reset button down for 90 seconds instead of 30, unplugging the router from power and then re-plugging it partway through as described in these instructions for the 30-30-30 hard reset rule. This more involved reset process may not work on some routers and should only be tried if the basic 30 second version does not work.
To avoid Internet connectivity complications, disconnect the broadband modem from the router before performing hard resets.
Mar 01, 2014 | Computers & Internet
Wireless is not working
Hi..
Based on the information you have provided, it seems that the issue might be due to the Wireless Network Driver or the settings.
However, please try performing the steps which I have mentioned below:
1) Verify the physical wireless switch is turned on. Refer to the user's manual for instructions 2) Reinstall the original wireless adapter driver. Uninstall the driver from device manager. 3) You may download the Wireless Network Driver from the manufacturer website. 4) If possible test, another computer on the wireless network. 5) If another computer is unsuccessful, contact the wireless router manufacturer or ISP to verify they are working properly. 6) Boot the computer into safe mode and test the wireless connection in the Internet Explorer browser. 7) If the connection works in safe mode, the issue is likely caused by anti-virus or anti-spyware software. Configure the software properly per the manufacturer's instructions. 8) Check the WAN IP address of the router as per the manufacturer's instructions. 9) If the router is not getting a WAN IP address, the issue is likely caused by a problem with ISP. 10) Reset the router and/or modem per the manufacturer's instructions. 11) If available, install a firmware update for the router and/or modem. Check the manufacturer's Web site for updates and instructions. 12) Check to determine if wireless interference is causing the issue. 13) Try adjusting settings on the WLAN router, such as the wireless channel frequency or cloning the MAC address.
Please try performing all the above mentioned steps. Performing the above steps should resolve the issue.
Hope this helps.
Please feel free to contact for further information and assistance.
Dec 19, 2010 | ASUS Eee PC 1000HA Notebook
Cable provider had to change modem, and now my wireless router isn't reconize how to fis
In checking if you're computer is properly connected to the Linksys Router, you will need to perform four steps:
i. Checking the Physical Connection to the Router
ii. Checking the LEDs
iii. Checking the IP Address of the PC
iv. Pinging the Router
NOTE: To check the computer's connection to the router using Mac, click here. If you are using Windows Vista, click here. For Windows 7 users, learn more here. For Windows 7 users, learn more here.
Make sure that the computer is connected to one of the four Ethernet ports of the router and the modem should be connected to the Internet port. For more instructions, click here.
Checking the LEDs
The Linksys router's LED lights will indicate the status of the connection. After connecting the broadband modem and the computer to the router, make sure that the LED lights are lit up. For more instructions, click here.
The IP address of the computer is another indication that the computer is properly connected to the router. For instructions, click here.
Thumbs back!
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
Cable modem internet works when directly plugged into desktop, but when run through the router, no connectivity
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform five steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the Router's LEDs
  4. Configuring a Linksys Router for a Cable Connection
  5. Power Cycling
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb4682-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports. For instructions, click here.
After connecting the devices, check the LEDs by following the instructions below.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
After checking the router's LEDs, configure the router for cable Internet. For instructions, follow the steps below.
kb4682-002_en.png For Telstra Cable internet users, please contact Telstra to confirm if your internet connection is using DHCP or HB (Heart Beat) signal. There should be no other machine running HB client upon doing this procedure.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE
: If you are using Mac to access the router's web-based setup page, click here. If you forgot your IP address, click here. If you forgot your router's password, click here.
Step 2:
When the router's web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select Automatic Configuration - DHCP.
(a) If you are NOT using Telstra HB, proceed with DHCP setup.
NOTE: If you are a Telstra Cable internet user and you're using WRT120N, WRT160N v1, WRT320N or WRT610N, please select Telstra Cable.
(b) If you are using Telstra Cable, proceed with the following setup. Obtain your user name and password from Telstra. Please disable any HB client that might have been previously running on the PC after the router is configured.
Step 3:
Click kb4682-005_en.png.
Step 4:
Click MAC Address Clone.
Step 5:
Select Enabled and click Clone My PC's MAC.
Step 6:
Click kb4682-012_en.png.
Step 7:
Click Status. Check the value of the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem. For instructions, click here.
NOTE:
If the Internet IP Address is all zeroes (0.0.0.0) click kb4682-008_en.png first then click kb4682-009_en.png. If the Internet IP Address is still all zeroes (0.0.0.0) perform a power cycle. For instructions, click here.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment. For instructions, click here.
Once the router is configured, perform a power cycle. For instructions, follow the steps below.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router's power cable.
Step 3:
Unplug the Broadband modem's power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem's power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem's lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router.
Sep 28, 2010 | Linksys Wireless-G WRT54G Router
I have reset my tw100-s4w1ca trendnet router,but still default username and password dont match
There are two kinds of resets in a router. Soft reset(reset the connection) and hard reset(reset all the settings). I think what you have performed is a soft reset. To perform a hard reset press and hold the reset button for 10 seconds. Please be aware that if you perform a hard reset you will have to re-configure your router before you connect to the internet, so make sure you have the settings handy. The default username and password is usually admin or Admin.
Let me know if you need further assistance configuring the router.
Sai.
Oct 12, 2009 | Trendware TRENDnet TW100 S4W1CA...
I forgot my password and i need to put a password on it so its not free for everyone else
perform a reset on the unit by following the instructions at
http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Please note that this is a factory reset so you will lose ALL settings.
I suggest you perform a backup from the web administration page to save all settings you've created such as port forwarding rules etc
Oct 10, 2009 | Linksys Wireless-G Broadband Router
HOW DO I TO GOT THE METAL CASE FOR A MA-1020W ,
That part may not be available anymore.
I would call Encompass toll-free at 866-779-5835.
Good luck.
Sep 25, 2009 | Goldstar MA-1020 850 Watts Microwave Oven
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
