I need schematics for a PC-735 copier, we think the spring came off of the Idler Gear.
SOURCE: Where can I get a .PDF of a user guide for Canon
Canon 720,735,740,770,790
Код ошибки
Описание
C
No problem. Means that the machine is correcting the fuser film tracking
CC
Drum must be changed. Could be the drum serial
number is identified by the logic as being non-compatible to that
particular copier
E000
Low fuser temperature
E001
High fuser temperature
E002
E003
Erratic fuser temperature
E007
Fuser film off track and will not repair itself
E010
Main drive problem
E030
Counter problem
E064
Scan problem, or power supply
E202
Scan problem
E210
Lens drive problem or lens sensor
E220
Exposure lamp stays on or off
E240
DC controller (main board) or composite power supply
E261
Zero cross problem. Power frequency or composite power supply
E400
Communication problem between boards
E803
24 volt problem
E0
Fuser problem
H
Fuser overheat
