Computers & Internet Logo
Anonymous Posted on Jan 19, 2013
The recovery of my laptop was interputt - Computers & Internet
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Jan 19, 2013
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1015136
Points
21773
1helpful
I need a gateway laptop recovery cd
Gateway does not provide recovery CDs for their laptops. Instead, they provide a recovery partition on the hard drive that can be used to restore the laptop to its original factory settings. To access the recovery partition, you will need to press a specific key or combination of keys when the laptop is first turned on. This key or combination of keys will vary depending on the model of laptop you have. You can find instructions for accessing the recovery partition in the laptop's user manual or on Gateway's
tip
How to install Recovery disc on your laptop/computer
Formally, when you purchase a laptop or desktop computer, an operating system disc comes with it. But these days, such disc does not come with most laptop or desktop computer because it is already installed in them which is called recovery disk. This has a great advantage, because if it was on a disc, it will have a scratch and it cannot last forever because it might get lost or damaged. So, having it already installed on your laptop or desktop computer by your computer's manufacturer is a very good idea.
Most people are not aware that this recovery disc is on their laptop or desktop computer. And some might know, but don't know how to use or install it.
A Recovery disk is used to repair windows operating system when it has a virus or when operating system is malfunction. Reinstalling windows with recovery disks helps to recover your computer from any damage.
First, you need to confirm whether your laptop or desktop computer has a recovery disk on it or not. To confirm, click Start Menu, scroll to "My Computer" and click on it. Beside your system's "Local disk (C:)" you should find "RECOVERY (E:)" Click on the recovery disc and you should find a golden padlock with "RECOVERY" in front of this. Also confirm the and make sure it's is a minimum of 6GB.
Now, to install/run your system's recovery disk, go to;"Start menu" > "All Programs" > "Backup & Recovery" > "Recovery Manager". Read and follow instructions and you will definitely perform the recovery successfully.
Lastly, make sure you perform the recovery white your laptop adapter plugged to AC and do not run the recovery on battery. There must not be interruption of any kind in the process of the installation.
Good luck.
on Nov 07, 2010 • Computers & Internet
How do I reset my Toshiba Satellite 1800-S207 laptop to original factory settings
Satellite 1800-S207
Windows 7 and earlier Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden image, you can restore your computer to its factory-fresh software condition.
How To: Perform system recovery - Windows 7
The following article will show you how to perform a system recovery. To Recover or perform a system recovery means to take the laptop back to factory settings (default settings). System restore means to go back to an earlier point in time on the computer.
There are two methods to perform a system recovery:
  • Using Partitioned Recovery Method (Free Recovery)
  • Using Recovery CDs / DVDs / Media
Details provided at the link listed below.
http://forums.toshiba.com/t5/System-Recovery-and-Recovery/How-To-Perform-system-recovery-Windows-7/ta-p/279643
Restore means to go back to an earlier point in time on the computer.
Refresh means PC settings will be set to default without effecting personal files or settings.
Reset means back to factory settings. (default settings) - deleting all personal files, programs and settings. Similar to Recover or Recovery
Windows 8 Toshiba laptops have many restore and recovery options available depending on your needs. To better understand these options and how they affect your computer, please view the video available in the linked article below.
http://forums.toshiba.com/t5/System-Recovery-and-Recovery/How-To-Understanding-System-Restore-Refresh-Reset-and-Recovery/ta-p/342690
Restore hp pavilion dv7 1464nr to factory settings windows
Step 1:
Which operating system ?
Restore Hp laptop factory settings without a Restore Disc Turn on the HP laptop. When the blue HP screen appears, press the "F10" key repeatedly until the "Recovery Menu" appears. A progress indicator informs you of the time before the recovery process is to take place. Click "Next" in the Recovery Menu. Decide whether you want to perform a nondestructive or destructive recovery. A "nondestructive recovery" does not format the laptop's hard drive or erase any personal files on your laptop. However, a "destructive recovery" formats your laptop's hard drive and erases any personal files you have on your laptop. Click "Yes" to execute a "Normal, nondestructive recovery." The restore process begins and your laptop restarts. Alternatively, to execute a destructive recovery, click "Advanced." Click "Yes" to start the "Destructive recovery." The restore process begins and your laptop restarts.
Restoring with CDs Back up all crucial user files if you are able to do so. If your computer will not burn CDs, use flash drives of 4GB or higher to store your data. Alternatively, you can use your network to transfer files. You can then back up your data to CDs at your leisure. Detach peripheral devices such as removable media drives, USB drives and your printer before recovering. Also remove any additional hard drives by disconnecting the cable from the back of the computer. Leave your monitor, mouse and keyboard attached to the computer. Shut down your computer. Place the first recovery CD in the CD drive. If your recovery files are written on a partition, you may be able to select system recovery from the splash screen and your computer starts. Select the recovery option you would like to use. To perform a destructive recovery, click the "Advanced" menu option. Select "Destructive Recovery" and click "Next." To perform a non-destructive, or system, recovery, click "Next" from the opening screen. Watch the computer while it is recovering to the factory settings. Watch for any errors, as the computer will wait indefinitely for a response from you, slowing down recovery time. Also, you may need to insert additional recovery CDs as the recovery program requests them. b> Restoring With Recovery Manager Click the Windows "Start" menu, type "Recovery" in the Search field and press "Enter." Click "Advanced Options," choose "System Recovery" and select "Next." If you are prompted to use Microsoft's recovery program, select "No." Choose the option to back up your files, if you haven't done it already. Once that is complete, choose "Next" to begin reformatting the drive and returning the system to factory settings.
Does a Hp 6720s laptop with XP pro have a built in recovery feature without a disk.
Hello, Most newer laptops now come without a recovery disk because the recovery is usually on the hard disk partition D.If you check yours and it has the partition for recovery, you can still burn this partition into a DVD media because the partition are usually large, incase something happens to your laptop recovery, you still have your recovery on your DVD MEDIA. Go to start>computer and check. Regards
How do I reset my laptop?
  • Connect the laptop to the power adapter and close any open programs.
  • Click "Start" and select "All Programs."
  • Choose "System Recovery" and "PC Recovery." A screen with recovery options will appear.
  • Click the "PC Recovery" option. Click "Next." The laptop will shut down and restart. A "Welcome to PC Recovery" window will appear when the laptop restarts.
  • Click "OK."
  • Select "System Recovery" in the System Recovery panel. The laptop will begin and complete a reformat of the laptop. All saved data and programs will be destroyed.
  • Click "Restart" when prompted.
  • 0helpful
    I cant make recovery for my laptop and idont have cd recovery
    what type of laptop do you have? there should be a recovery partition in your C drive. You could also try contacting the manufacturer if your laptop originally came with a recovery disk.
    Dear sir , please send me procedure, how to use recovery
    Here are recovery instructions for HP/Compaq laptops.
    1. Reboot, and repeatedly press F10 at the HP logo until the recovery screen appears.
    2. When the recovery screen appears, press "Next" and then "Yes" to perform a non-destructive recovery.
    3. To perform a destructive recovery, click "Advanced" and then "Yes".
    4. After the recovery is finished, the laptop will reboot.
    Grand Canyon Tech
    Grand Canyon Tech
