Question about Dewalt Saws
Blade keeps derailing
D28770 dewalt bandsaw
  • James Thompsom May 11, 2010
    Is this a two or three wheeled bandsaw?
I am not sure why you took the guides off in the first place,   That is definitely related to the problem but is it possible that taking those guides off created a deeper problem?
Posted on Feb 19, 2009
I need to replace the gear oil in a Dewalt D28770 portable band saw. what type of oil do I use
I suggest you buy the gear oil from Enco. And buy blades on sawblade.com
May 25, 2014 | Saws
How can I cut wood 3.5 inches thick with Dewalt Scroll saw?
nope... throat on scroll saw is of fixed height... beside, all scrollsaw blades are of fixed length, i would suggest use of bandsaw with very narrow blade with minimal kerf. do not use pressure on the blade! you will then have same cut through the thickness of the wood! setup bandsaw correctly, do not overtension it - see my other instructables pertaining to the bandsaw and regulation/setup of it
if you find my solution helpful - do not me shy... give some points... :-)
Jan 23, 2014 | Dewalt DW788 20" Variable-Speed Scroll Saw
Blade walks off the drive wheels
If the blade is walking off the wheels, the wheels are out of alignment with each other. This can be caused by loose screws that hold wheels on their pulley shaft, a worn or lose pulley shaft, worn or broken bearings, ect. Anything that holds or supports the wheels can be lose or worn to the point the wheels are out of alignment which affects the tracking of the blade.
Jan 24, 2013 | Dewalt D28770 Hd Deep Cut Variable Speed...
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
D28770 dewalt does not turn the blade. Light works and switch works but not even a hum from the motor.
Check the brushes, if they are worn down to where they are not making good contact with the armature, the motor won't work.
If the brushes are OK you may have to have the armature tested to make sure it doesn't have a short in it.
Mar 05, 2012 | Dewalt Saws
I need an instruction manual for a DeWalt DW100 bandsaw.
Hi I have a manual for DW100 bandsaw. E-Mail : mikepat21@sky.com and I will send a copy to you. Regards Mike
Sep 06, 2009 | Dewalt Saws
D28770 dewalt bandsaw derails blade
Over-tensioning the blade can and does cause the blade to "crawl" off.
Jan 26, 2009 | Saws
D28770 blade keeps derailing
I need to order a new tire for 12 in. jet bandsaw but i can,t find a place to order one
Jan 23, 2009 | Saws
Saws Logo
258 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
