Question about Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
Gas oven electric short out and turns oven off
Oven turns on than electric panel on top goes out and oven shuts off.... electric panel comes back on after a few minutes
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Model number?
Posted on Jan 19, 2013
SOURCE: Slow heating and control panel clicking
I have a similar problem with my Frigidaire FAM156R1A Air conditioner. The unit is stuck on a temp setting and occasionally makes a beeping sound. Repair tech came out and told me the control panel was broken and that this is a common problem. I wrote more detail here: http://www.epinions.com/content_404700761732
Posted on Oct 04, 2007
catriver
  • 878 Answers
SOURCE: FRIGIDAIRE GAS RANGE FGF378WCC
sl, because it't happening to both broil and bake the first thing I would suspect is the temperature probe. You should ohm it out. You can do this either at the board or at the harness connection in back. For the board, remove the back panel, there should be a 8 pin connector to the left of 3 relays. On the harness measure the resistance of the wires going to pins 1 and 2. On the shemantic it shows them being the 2 on the bottom. Should read around 1100 ohms at room temp. If you cant get a good reading on it there, Remove the probe from the inside oven, remove the screws and pull it out until the harness connector comes through, disconnect it and ohm it out from there. I don't think that both ignitors would fail at the same time so Im leaning toward the probe. Catriver.
Posted on Dec 11, 2007
Krazytech
  • 725 Answers
SOURCE: Frigidaire gas oven locked problem
you have a short in the Electronic Oven Control. if no error codes only two in this EOC
F1 or F3
Posted on Sep 13, 2008
daddy1264
  • 76 Answers
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Posted on Jan 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: The electronic display went out on my gas range so
This is often due to loose or corroded connections in the wiring.
Unplug the range.
Open the rear of the control panel.
Remove,then re-attach all wires on the control.
If you see any terminals corroded,clean them with a pencil eraser.
If this does not correct the problem,the clock must be replaced.
Posted on Dec 18, 2010
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
Hi, I have the Jenn Air model SVE47100 and it seems I have a short. My oven is turned off by means of turning off only through the electrical panel. I can not seem to turn it off. If it gets electricity,...
Sounds like the broil relay on your ERC (electronic range control) / clock is stuck. Until it's replaced the only way to keep it off would be to cut power to the range.
Jan 18, 2011 | Jenn-Air Ovens
Broiler will not shut off
no question you have a short in electrical . you do need a tec to ck this out . unless you have electrical expertise . it sounds like control panel or shorted( melted wiring ) mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Nov 18, 2009 | Stoves 900DFa Dual Fuel (Electric and Gas)...
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
F1 or F3
Sep 13, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Oven does not light
even if the ingitor glows, and the oven wont lite, the odds are that the ingitor is bad. it must draw 3.2 amps to open the gas valve. the only way to test the ignitor is with an amp probe. replacing the ingnitor is about 90% a sure thing.
Dec 08, 2006 | Hotpoint RGB745 Gas Kitchen Range
Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
