Question about Frigidaire Dishwashers
Frigidaire dishwasher error code
Frigidaire Professional Series AquaSurge with Speedclean - error code uo. What's wrong?
  • Official Brand Answer
  • 4,342 Answers
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
Posted on Jan 22, 2013
2 Suggested Answers
  • 56 Answers
SOURCE: I own a frigidaire professional and the low light
the low light refers to the rince aid being empty. fill it back up and the light will turn off
Posted on Feb 08, 2010
Uo error code frigidaire pro series dishwasher
Check manual. If no answer there contact manufacturer or service agent.
Aug 10, 2014 | Frigidaire Dishwashers
What does the Frididaire dishwasher error code uo mean?
Good Morning Friend, this is Z. Thank you for your question!
Error code UO commonly means that the vent is in an open position. While your Frigidaire dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly.
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your dishwasher. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
Jul 07, 2014 | Frigidaire Dishwashers
My frigidaire professional series aquasurge won't start
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# PLD3465REC, will not start. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire 24 in. FDB4315LFC3 STAINLESS STEEL ERROR CODE UO
Hi Mark, thank you for your post!
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn your dishwasher on. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
Jan 18, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
Found an oval rubber gasket in bottom of 4000 series AquaSurge with speedclean dishwasher model PLD4555RFC3. Look to go inside dishwasher but cannot locate where
Hello, Thank You for using FixYa. I will be helping you today.Here is a parts break down of your model CLICK HERE See if you can locate it im not aware of an oval gasket.
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Frigidaire Dishwashers
I own a frigidaire professional and the low light stays on what is wrong? Professional Series Aquasurge with Speedclean
Feb 05, 2010 | Frigidaire Dishwashers
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Getting uo error code on my new frigidaire dishwasher
Mary,
The problem you are having is the vent assembly blower part number 154562802 for 4000 series aquasurge dishwashers by Frigidaire. The service manual will tell you to replace this part but it can be fixed in most cases. This part is located on the top, right back of the tub. You will have to remove the unit from the cab to get access. Remove the part and disconnect the wires. There are two fasteners on the cover of the vent assy unit with the note "Do not remove cover no serviceable parts". Inside you will most likely find the rubber valve clogged up preventing the valve from closing enough for the pickup to break the contacts with the switch board. I would recommend removing the rubber value from the unit by pulling the wire clip pin. Clear the rubber valve and reinstall. Make sure you have the valve in the correct position and reinstall the pin and fan and replace the cover and reinstall the vent assy. You should be good to go for another year or so until the build up needs to be cleaned again. This is a very poor design by Frigidaire.
Good Luck
Jun 14, 2008 | Dishwashers
Dishwashers Logo
571 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
