Question about Kenmore 22422 Top Load Washer
It takes three cycles to dry clothes, andthere is heat?
Kenmore heavy duty plus drier
    Sergeant:
  • 311 Answers
Dry a load with your house ducting hose off the back of the dryer.if it now dry's fine you then know your dryer is fine.and you will need to have house ducting cleaned.if not drying will need to take apart dryer and clean all air path ways,which is good to do even if your house ducting is the issue.because that kind of blockage can causes a lint build up in the dryer.ps all brands but GE only have one element.so if getting heat your element is working.thats just in-case you were thinking that question
Posted on Jan 26, 2009
    President:
  • 2,992 Answers
The most likely cause is poor airflow. This may be due to a clogged lint screen (should be cleaned after each load) or a clogged vent. Run the dryer empty and feel the airflow from the vent outlet (where the vent exits the house). If there isn't a good strong flow of air, remove the duct where it attaches to the dryer and check for flow right at the dryer. If there still isn't good flow you may have a bad blower, but chances are the duct is clogged with lint. If it's the white plastic flexible duct or the corrugated metal kind you should replace it with solid 4-inch vent pipe. This will give the best airflow and the smooth walls won't promote lint buildup.
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My dryer heats but takes two cycles to dry clothes.
Check the hose in the back and vent to make sure it is breathing properly first. Most driers have a thermistor moisture sensor. Try replacing it first. It nether of these works your heat strip may be shorted so only heating partially. Most driers have two or three thermostats also. Two on the heater cover. One is the high temp and one is the low temp. Usually the high heat will be the problem (cuts out to early before the heat strip fully heats). Others have a third one on the exhaust blower. Check these at room temprature with an ohm meter. They should have continuity. If not replace. Thermostats that are open with no continuity will usually cause the heater not to heat at all. Thermostats can get old and stop working at their intended temp. Replace one at a time
Jan 17, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Mar 21, 2008 | Dryers
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
