Question about Hyundai 2007 Santa Fe GLS
No power when put into drive
The car starts without any issues. An orange check engine light comes on most times the car is started. Occasionally an orange light that looks like a chassy will light up - although I am not sure what this light is supposed to indicate. The car will shift into reverse smoothly, and the idle is strong enough to back out of the drive as normal. When the car is shifted into drive the car creeps at less than 5 mph, and pushing the gas gets no response at all - not even an engine rev (or so minimal that it cannot be perceived). Shutting the car off, removing the car, and restarting the car, sometimes multiple times seems to resolve the issue. This only seems to happen if the engine is cold - either first thing in the morning, or if the car has sat for a while - several hours. The car is stored in a garage and not parked out doors.
  • James Hill Jan 19, 2013
    *removing the KEY - not removing the car*
  • 28 Answers
If you have somebody push the gas a little while you watch the throttle cables (while in park of course, lol) does it move or seem to have a little slack? does it have any slack at all when not having gas pedal pushed and you push on the cable a little with your finger, no harder than your eye when shut. sorry for the poor example. i am not a hyundai driver so I do not know much at all about them but I do know cars. I can try to help if you will answer.
Posted on Jan 20, 2013
Why does my 1999 Saturn suddenly die out while driving and won't start for about one minute then it starts
car turns off while driving without warning - 1998-2002 ...
https://www.ifixit.com/.../car+turns+off+while+driving+without+wa...
iFixitwhat would cause my car to turn off while driving & what cause it to start with ... Before you do these, you may consider doing a quick check of your battery terminals. ... So changing out the ignition control module is not a one fix for life job. ... and all thesudden the check engine light would come on and the car would die.
Diagnosing Intermittent Stalling Issues - Underhood Service
www.underhoodservice.com/diagnosing-intermittent-stalling-issues/
Oct 1, 2008 - Replacing a perfectly good ISC motor or solenoid won't fix the ... If the engine stalls while idling or driving, the engine may be running ... The engine may startand idle fine, but run out of power or even stall at highway speeds. ... If the engine is running normally one minute, but suddenly quits, .... Then dies.
Engine Performance Problems Due to Crankshaft Position ...
Dec 26, 2015 | Saturn Cars & Trucks
What could be wrong with my Toyota Echo if the engine chugs while idling, and the car loses power when accelerating (stalling out if accelerating too quickly)?
There are numerous things that will cause this problem. If the check engine light is on, have the codes checked to see if there is a problem the computer has found to cause this issue. Even without the check engine light on, there may be a code stored. You can also do a visual inspection under the hood for any disconnected hoses causing vacuum leaks. These are the best places to begin with diagnostics
Aug 03, 2015 | 2003 Toyota ECHO
2004 honda accord accidentally put power steering fluid in my engine and addednoil. Car freaked out
You might have two issues here. First drain the engine oil and replace with fresh. Second it seems like you may have an electrical issue. On that problem, check your battery connections. THEY MUST BE CLEAN!! Then you want to check basic battery voltage. Should be at least 12 volts. If not then you have a bad battery. If the voltage is good then I have questions. What lights are flashing? external or dash lights? Does it have a security system other than what comes stock? and when you say it wont start do you mean that the engine wont turn over at all? or will it turn over for a long time and not start?
Mar 08, 2013 | Cars & Trucks
95 nissan pathfinder has bad mpg, dies, and jerks
Anytime the check engine light comes on, you check the computer for trouble codes. The codes will not tell you what to replace, but rather what to check.
Let me know what you find out.
Aug 24, 2012 | 1995 Nissan Pathfinder
Is this a problem with my Santa Fe's computer?
as for the check engine light sometimes the tightness of your gas cap can make that light come on and stay on, try tightening it or loosening it just a little bit. have no clue on the rest of the issues or the possibility of it all being linked but i know the cap cap has been the culprit for check engine light issues i've had when mechanic checked and said nothing wrong!
May 14, 2012 | 2007 Hyundai Santa Fe Limited
Hey hey!! my check light comes on and starts to flutter and so does the engine! eventually loosing all engine power and it wont even drive??? please help if u know what i mean??? (the orange check light in...
These engines have a self-diagnostic system built in. Find a manual on how to engage this self-diagnostic - you jump a couple of leads in a junction box and then count the number of times the check engine light blinks in succession. Refer to the Toyota manual for identifying what system is affected. Sounds like a critical component is out - fuel pump perhaps. Don't quess - use the diagnostic system.
May 13, 2010 | 1989 Toyota Camry
1997 Maxima Starting Problem, O/D blink, Cruise Control issue
i assume this car is automatic the o/d light is the overdrive light which is controlled by a little button on the gear select lever and usually service engine light comes on when it is due to be serviced like every 5,000 km or so hope this helps regards Jim
Mar 26, 2009 | 1995 Nissan Maxima
Electrical Gremlins
Again, check the recall on the headlights.
Oct 12, 2008 | 1986 Nissan 300ZX
Hyundai 2007 Santa Fe GLS Logo
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Jerry Kramer
Jerry Kramer
tony wahlman
tony wahlman
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
