Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
Microwave does not heat anything
The microwave works other than heating food or liquid.
    New Friend:
How to rost
Posted on Jan 21, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave partially heats
Assuming your power line voltage is right, bearing the whole thread in mind, I'm sure you have a bad magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you follow the safety & disassembly info, this is not a difficult job for a do-it-yourselfer.
Posted on Dec 05, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Stopped heating food
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here onFixYa:.
You can find helpful exploded view diagrams and order parts for many brands by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you may be able to download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 01, 2009
  • 1214 Answers
SOURCE: Microwave hums
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Posted on Jan 24, 2009
danforddan1
  • 192 Answers
SOURCE: doesn't heat the food
The part you need is sometimes call a megatron, they may call it something now, but its the power that radiates through the unit. I think this may be the culprit Sorry but this is not a cheep fix. you may want to do a cost comparison . This happened to me only after the warrentee had expired . good luck with it. DFD
Posted on Apr 11, 2009
Sailorm0on
  • 61 Answers
SOURCE: Rust inside the microwave oven
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
Posted on May 15, 2009
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
I have Kenwood KGTS23 microwave, it looks working but it stopped warming the food
The heart of any Microwave is a part that generates the actual Microwave radiation that heats the food and liquids, it is called the Magnetron, it is the most expensive part of the oven and unless the oven is under warranty it is cheaper to just replace the oven with a new one than to have the Magnetron replaced.
Feb 01, 2012 | Kenwood Microwave Ovens
My Delonghi AM820AGX microwave no longer heats up liquids/food. It turns on and looks like it works, but when I test the liquids/food, they are still cold. I could have possibly changed the settings...
It souds like a busted MAGNETRON, and replacing it usually costs almost the price of a new oven...
Nothing to do with a setting... Sorry!
Apr 15, 2011 | Microwave Ovens
I have a Magic Chef Microwave model # MC0160UB serial # DJ07201331 It acts like it's working but does not heat food/liquids. It's not very old.
There are three possibilities, the first is a bad magnetron that heats the food,"common problem" next the high voltage capacitor and diode do fail on occasion, the cost to repair may equal the amount of a new one.
Feb 04, 2011 | Magic Chef Microwave Ovens
Everything seems to be working except it won't heat anything it just suddenly stopped heating.
Did anything spill or blowup inside? Remove the glass tray and be sure all is clean and dry.
If something did blow up (food or liquid), find the small mica window on the inside, and carefully remove it, clean up, dry off in the cavity too, and replace it.
Try to use. This has fixed 3 different microwaves for me. Hope it helps you.
Nov 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microvave does not heat anything up. The light works, turntable works, the 'oven' goes 'on', but neither the food nor the liquid heats up. It was working one day and then not, the next!
At minimum, it'll be a High Voltage fuse blown. There could have been a power surge, or it could be an indicator of something more wrong with the microwave. Not that expensive to fix.
At maximum, it'll be the magnetron (the component that creates the microwaves). This could be an expensive job.
Refer to your manual or to the manufacturers website for information about repair locations.
May 16, 2010 | Microwave Ovens
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
Microwave Won't Heat
Check the door safety interlock switches. Be careful of the capacitor, potentially dangerous.
If the switches dont make a connection, the magnetron will not energize ... no heat
Apr 19, 2010 | Microwave Ovens
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
