Question about Kenmore Oasis HE 27082 Top Load Washer
Holes in clothes
I am having a problem with our washer. We have had 3 repairs on the dryer. At last maybe it's getting better... Now we are having our clothes torn in the washing machine. It has happened on at least 5 occasions and we are left with clothing with small holes in them. It has happened on several different cycles. The clothes have been newer and in several cases brand new. I called service to come out and he couldn't find anything wrong with it. He thinks that it is the nature of the machine and that it just washes roughly. When I went to the Sears store yesterday they said that they had NEVER heard of anyone with that complain before. Am I the only one??
  • Momcat Sac Nov 12, 2007
    Yes! Our new Kenmore Oasis HE seems to be leaving holes. The salesman said he has never heard of it, but recognized that since friction is the machine's washing motion, it is not out of the question. His only solution was to trade it in for a different model.
  • Deby O Jan 18, 2008
    My machine which is only a year old is eating cloths, ripping material, breaking strings, etc. The repairman says nothing is wrong with the machine and Sears told me too bad. I am thinking of contacting a class action lawyer.
    Problem Solver:
  • 15 Answers
Sometimes in occasions like this there is 2 possibilities it is a screw from someones pocket that is lodged in the drum or the more common one is a bra wire which is a lot harder to see.use a torch inside the drum and feel with the palm of your hand for any irregularities. good luck
Posted on Jul 19, 2007
Water coming from under appliance
Maybe your dryer is not drying!!!!!!!! Is it getting hot? Heat element ok? Maybe the washer is not doing a good enough job during the spin cycle and leaving clothing excessively wet.
Sep 08, 2017 | Refrigerators
Everything works except the clothes will not agitate.
Maybe you are not saying the correct thing to the cloths to get them agitated, they can be very stubborn. That answer is the best I can do with model etc you gave me. Try these links for more help:
Free Online Appliance Repair Manuals Do it yourself washing machine and dryer repair help
http://www.partselect.com/Repair/Washer
DIY Washer Repair
May 30, 2016 | Washing Machines
Water coming out front of condenser
It is difficult for me to understand why any water should be coming from the dryer. Your washer maybe the fault, clothes should be, at best, damp from the washer with very little excess moisture. Check to see if your clothes washer is spinning, if necessary try turning off the water supply to the washer and run another rinse/spin cycle, if your clothes are still wet or dripping then your washer needs repair. Check that first... And report back
Jan 21, 2013 | Hotpoint TDC32 Electric Dryer
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
Dryer is squeeking. Ok to oil in hole on back?
no oil.there's a kit you can buy it's a belt rollers and pulley inside the kit,change them out and you should be fine,don't put any oil in there it will get on clothes
Apr 18, 2010 | Whirlpool WED5500S Electric Dryer
I have a sour smell coming from my washer that does not seem to go away, what is the problem? I have seen many other postings on the internet about their having this problem, seems to be the washer.
After the odor has been removed washing habits need to change so it doesn't return. Washing machine odor is caused by
1. Overuse of detergent. Use no more than 1 tbsp of whatever detergent is used (unless washing soiled clothing).
2. Using fabric softener because it's dispensed in the rinse cycle. Dryer sheets or dryer balls are better options. Dryer sheets can also be overused and coat the inside of the dryer with siliconized chemicals that cause clothing to retain odors. Sensors inside the dryer can also be affected. The sheets can be torn in half or thirds
3. Using mainly cold water for washing is fine but makes preventive maintenance important. A hot wash or soak as your last cycle on wash day will help to dissolve residue.
4. Many front loading washer have a filter/trap that will catch debris. A partially clogged filter/trap can cause draining problems and odor. Save money on appliance repair by cleaning it yourself. Consult your owner's manual for instruction.
Mar 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My clothes are hot, but still wet. I've run the dryer on every dryer cycle option, and the clothes aren't dry. What could it be?
Them dryers are notorious for having a plastic blower wheel which gets loose and won't allow for correct air flow. here are some repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 04, 2010 | Maytag Performa PAV2200
Holes in clothes
run a old hosiery or cotton wad (like from holloween) around the inside of the drum. see where it snags,
the drum is warranted for a very long time. (don't know exact)
Mar 26, 2008 | Kenmore Elite 45986 Front Load Washer
Washer Creates holes in clothes
We purchace a washer and dryer in Dec 08 Kenmore HE energy star. They started destroying cloth about 2 months after purchace.
under our warranty and many many calls they sent a new set. 2 months later same problem. HELP
Nov 12, 2007 | Kenmore 98702 Stacked Washer/Dryer
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
96 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
